Alberta 7.3
I'm using a 09 Jetta CBEA for my Ranger swap. The Jetta A/C compressor utilizes a control valve rather than a pulley clutch. I will be using the Ranger A/C compressor to keep the A/C system plumbing all Ford. I want to use the Jetta Climatic control head circuit board to control the A/C system since it will control the radiator fans via CAN and also will provide low ambient cutoff and compressor cycling, where the "dumb" Ford head merely turns on power to the compressor/pressure switch circuit. (I will have to graft in a few temperature sensors to the trucks ductwork.)
My big question is does the solenoid valve signal on the compressor just get full 12V on/off that I could power a relay to run the clutch, or is it some funky PWM signal to modulate the valve?
