Nevada, it would be no problem to get one, it's a required tool to have in the garage anyway.....
And, as mentioned above, I'll get injector deviation checked. My understanding if one (injector) is weak the ECU "weakens" the remaining injectors to provide for a smooth idle?
Would I "T" into the vac line going to turbo from the N75 and monitor what the vac is doing as I drive (or someone drives
)? I have actually been thinking it would be nice to have a boost gauge right about now....to see if it is actually making any boost....but per my guru requested follows along pretty well w/actual boost so...? I can't believe how much stronger she ran before. My local guru says the BW turbo must have been stuck giving me max boost all the time. I can't swallow that because with the new PD140/tune/3 bar it was supposed to make more boost than the original BW turbo....? BUT, otherwise the car runs and drives perfect as a cummuter.
I would like my clutch to get the workout it deserves....
PS: When the shop checked...Mity-Vac at the actuator it began to move at 4mmhg and stopped at about 18 as I recall. But that doesn't tell me "when" the ECU commands it to move...correct? We did adjust the stop screw (read +/- on that one) and got the Mbar spread from 120 to 80...group 11 and I think that adjusts the vane position?
MAF unplugged, car runs
NO different. I replaced it....as I've read it defaults to a "limp" home tune?.....car runs the
SAME. Do I have an issue with MAP
I apologize as I don't have the knowledge most, if not all of you have on this board. I also realize the importance of having a Vag-Com to run logs and post screen shots. The best I can do is have the shop do it and email the shots to me....when their time permits.
