Metalnerd
About a year or more ago, (~50 K miles ago) I had the power loss after sustained boost. Per suggestions from Mickey or GoFaster, I swapped out the signal hoses and the N75. Not sure which worked, I did both to fix it ASAP (Poor Scientific approach, two variables, confounded)
Well, this morning, after some "spirited" driving up the mountain, the same thing happened. Sustained max boost triggers a whimpy mode that goes away when the car is shut off and restarted. I can trigger it often.
I will put fresh hoses on this weekend.
Do those N75s have a limited life span?
I may check the signal hose inside the ECU box, as a last resort.
Any other suggestions?
BTW - The car is unmodified
