twentyeight
My block is at another machine shop with the pistons ready to be bored .5mm over. They'll be measuring each piston individually and boring however much over I tell them. I have read a few times that the cylinder to piston clearance should be 0.0012" to 0.0015. I told the shop this and they said it would end up between 0.001 and 0.0015, which made me nervous it could possibly run too tight.
So after much searching I found a document on a Czech server detailing Nüral's pistons. The relevant page is 1248 (which is 1323 of the PDF). The pistons I have are etched 87-114907-90, which seem to be listed as 0.070mm clearance. That's .0028" which is significantly larger than the other numbers I've read.
Another thread talks about .5mm over pistons from IDParts, which show in the picture as being 87-114907-60. The -60 is the "version" according to Nüral. The document above lists them as requiring 0.05mm or 0.00196" clearance—*still not the 0.0012 talked about in the thread. Interestingly, this piston also 0.02mm larger than the -90 that I have.
I'd like to call the shop tomorrow to correct the specs - I'd really appreciate an explanation of typical TDI piston to cylinder wall clearance and what to tell the shop.
