I've developed a pretty dramatic "clunk"-ing noise over the last three days, and I wonder what opinions folks may have.
A couple of caveats:
1) I just replaced the suspension (myself) - Koni FSD w/Eibach springs... all went well, I didn't have to lower the sub-frame, and I've been running it for ~10 days with no clunk
2) The clunk does seem to have started after hitting a speed bump, or rather, the side of a speed hump that does not quite span the entire width of road... I was forced to the right side of the road by an oncoming trailer as I approached a speed hump... the left front went over the hump, while the right front did not have to, and I definitely hit *something* on the under carriage. I first noticed the clunk on the way home that evening, and it seems to have gotten marginally worse since.
I don't get the clunk going over bumps, unless the car is being torqued (twisted); it's more common while turning, right or left, especially if getting on or off the accelerator or brake. I can take on- and off-ramps with no noise, however.
It's a definite CLUNK... a borderline thud... and you can feel it in the car and it's not feint. Only happens once, not repeatedly - motor mount? Doesn't sound to me like swaybar bushings.
I pulled the front wheels off last night to inspect bushings and tighten suspension bolts, but didn't find anything out of the ordinary. It's not readily apparent where I hit the under carriage either... the OEM (plastic) skidplate is intact, and I didn't notice any impact marks on the lower control arm or sub-frame.
I'll put it on the ramps tonight and pull the skidplate off... but what should I look for?
