prestipresse
[FONT="]This is my Golf. This is a resume of my upgrades:
I was running on a vnt 17, with a g60 vr6 cluth combo, 11mm pump with 205 injectors. it was running great at around 22psi.
In nov. 2009 I found a 2001 engine with only 15000km, I bought a vnt 20, added a peloquin LSD, FMIC, bigger injectors, bully clutch combo, intergrated engineering rods + tchip. [/FONT]
[FONT="]The power was great but I felt that I couldn’t maximize the torque with a front wheel drive.[/FONT]
[FONT="]Did some research and decided to install 4 motions from a TT. The transmission installed was the 5 speed from the TT. It was fast, but to short... perfect for the 1/4mile but not a daily driver!!![/FONT]
[FONT="]Bought a EFF from England, rebuilt the transmission with all new bearings and reinforce the 2nd gear shift fork... no brainer since I had the transmission in my hands.[/FONT]
[FONT="]
[/FONT]
[FONT="]Performance/Mechanical[/FONT]
[FONT="]-4motion swap from audi TT[/FONT]
[FONT="]-ERF 6 speed transmission from England with all new bearing [/FONT]
[FONT="] and reinforced 2nd gear shift fork[/FONT]
[FONT="]-Bully cluth and Fidenza pressure plate[/FONT]
[FONT="]-2.5 stainless steel exhaust after downpipe[/FONT]
[FONT="]-Magnaflow muffler[/FONT]
[FONT="]- 11mm fuel pump[/FONT]
[FONT="]-VNT 20 + stainless piping with p-flow.[/FONT]
[FONT="]-ARP forge steel head studs[/FONT]
[FONT="]-Forge Rods Integrated Engineering[/FONT]
[FONT="]-Brembo disque + ceramic pads[/FONT]
- Stage 6 custom ECU tuning
- Firad injector nozzles
- 1.8T front shocks with neuspeed coil
- rear audi TT complet suspension
- Short shifter kit
and more
These I took at the last H2O
More will come next spring!
PP
[FONT="]
[/FONT]
- Short shifter kit
and more
PP
