Day 40
I started out this morning by running my snow blower. Yeah, just what we all want to do, right? But it has to be done, so it is what it is.
After that, I spent a few hours installing my injectors into my 4-dr and hoping that it wasn't going to spend the winter not running at all.
And after doing everything I needed to do, priming the pump and injectors was the hardest part of today.
Got all that done, finally, and it started. Yay! The replacement pump I got off my spare engine leaks. Boo! I'm right back to where I was a month ago when my headache with that car started. Except it also runs really funny. Like, the compensation factors are way off, so I think this pump was mistreated by its former owner. Or a former former owner. Or a bad mechanic. Or just bad luck. I don't know, and I can't fix it, so I'll put my old pump back on and see if it is going to do better.
But you aren't reading this for that saga, and I'll get back to business.
Since I used a lot of time on that other car, I decided that this would be a good time to put the spare back in its home. I vacummed out the plastic dust I made when I trimmed and adjusted the right quarter panel, and set up everything to get started. I also figure this will be a good dry run in case the odds catch up to me and I have to use this spare.
Starting out:
I'm skipping ahead here. If there's a flat, then you'd have to unload the bed if you're packing anything, since you basically have to completely remove the bed panels. The skip ahead part is that there's 36 bolts that need to be removed to get the panels loose. If you used the provided bolts, you need a 4mm allen wrench to do it. It should take about 10 minutes or so. More if you're slow like me.
Now we're here. We need to remove the middle bar, #3. For this you need a 5mm allen, and a 13mm deep socket. A box end wrench is OK, but a deep socket on a rachet is better. Even better than that would be the rachet you would have to get those bed bolts out. So 2 rachets, and a 13mm deep socket, and a 5mm and a 4mm allen bits. About 10 more minutes to get the nuts off. Why? Those bolts are kinda long, and since the nuts are nylocks, you have to keep going until that nylon ring is out past the bolt threads. And there is not a lot of room, so each stroke is pretty short. That's why 2 rachets would be better than 1.
The C channels (the bars) have a filler piece. In the videos, you see a nice long chunk that is at least as long as the supports. Not anymore. Back to this in a minute.
Just drilling and nice 5/16" hole for putting this stuff together is OK. Drilling the hole and working the bit around to enlarge it a little like you had to do with every rivet hole is better. Much better. I had to work pretty hard to convince the bolts to depart the bar.
And this works up to the surface of the bar, (that is, you beat the bolt back as far as the support surface) so I used a punch to get the bolt the rest of the way out. Not something I'm interested in doing in the middle of the night along side the road. In the rain. Or worse, in a snow storm. So seriously, work that hole. (More on this issue later.)
So now you've got those stubborn bolts out, finally, and it's time to remove the bar. First you knock it down to the deck (formerly the trunk floor).
Then you slide those 2 fillers out from in between the supports (i.e. toward the middle, since that's the only place they can go anyway). Then you can roll it like this:
Until it is flat on the deck, and you can slide it out.
Which gives you room to get the spare out. Or in. Or out and then in.
And you are left, my case, with the spare in place. Installing the 3rd bar is the reverse of removal.
Now, many times, instructions in manuals of every source and derivation say what I just said - reverse the steps. Yeah. Except for me, since Murphy is continually hanging around - I'd like to fire him but it doesn't work - and the bolts just did. NOT. want. to. go. back. in. I ended up redrilling the right side in situ. Yikes, and I just cleaned up that space!!!
So, drill those <bleep>ing holes out before this situation comes up, or you'll be going home with either a large collection of parts in the back or something broken. Or multiple things broken.
At this point, I can also see wisdom in carrying some kind of fix a flat can of stuff just in case. A can won't help if you mangle a tire/wheel on the mother of all potholes (it's that season up here in NE), so it may be better to buy some help from AAA than hurt yourself. If you decide to build one of these kits, think about this issue. Mark's solution is cheap to provide, but I think the utility is somewhat lacking.
My friend, the owner of the metal shop, came in and saw the frustration on my face and after I explained the problem; he thinks we can come up with something better and much faster. We'll see. Thing is, our solution won't be free, or even cheap (like less than $10) to implement, but I've got to do something.
Also tonight I cataloged the wire colors going to the plugs on the buses (the wire bundles) going to the back. There's lots of stuff on the left side, and only 2 items on the right: the plug to the lighter power plug in the trunk, and the fuel door popper. That side I already folded back up front and under the tray in case I decide there's something fun to do with them. Everything else is on the left (driver's) side, including both tail light plugs. The bus just extends a little to cross that short span between the two taillights for the second light. I guess they figured it would be cheaper that way. Or maybe just simpler to build. Whatever.
Anyway, I'll compare the wire colors with the manual to see if there's deviations in my copy of the 2002 A4 chassis. I doubt there is, but now at least I have a nice chart that tells me what wire colors to look for when it is time to dig into the main wire bundle that heads aft on the driver's side.
Cheers!
PH
