In my attempt to validate the claims that water/meth injection provides added power.. I did a little dyno experiment.
Unfortunately, the Left Coast Diesel dyno could not get the torque numbers so this result is based strictly on HP output.
I got these results with my 03 ALH w/ a RC6 tune, Colt stage 2 cam, ported head, 17/22 turbo, 11 mm pump, R520's nozzles and Devil's Own WMI 250 psi set up w/ a progressive boost controller set to start spraying at 15 psi and reach max spray at 25 psi.
I ran 25% methanol solution.
I did four runs
Run No.2 was with a D03 W/M nozzle and produced 216.89 HP and MAX EGT's of 1190
Run No.3 was with the w/m turned off and produced 214.76 HP and MAX EGT's of 1600
Run No.4 was with a D04 W/M nozzle and produced 216.48 HP and MAX EGT's of 1180
Run No.5 was with a no w/m and some ghetto NOS spraying in the airbox and produced 278.18 HP and MAX EGT's of 1400
Based on my no Horse$hit experiment, and with all other things beings equal, my conclusions are:
1- WMI has negligible effects on HP output
2- Significant beneficial effects on EGT's
3- My optimum nozzle size is D03. (why go with a larger nozzle if I get essentially the same cooling effects)
You make your own conclusions...
I did four runs
