Cappattack
Hey all! I recently acquired my first ever TDI and boy am I excited! She's a 2002 Jetta TDI, alh with an 01m automatic (4speed). Had 230,8xx miles when I bought it, now at 231,783 miles. Do not have VAG-COM. Originally started a build thread here: http://ecomodder.com/forum/showthread.php/jettad-build-thread-34409.html
So far I have done a ventectomy, bled brake fluid, gotten the rotors turned, replaced fuel filter and lines, replaced glow plugs, replaced egr valve(m) (stuck open), replaced vacuum pump(m) and all vacuum lines, oil and oil filter change, cleaned PCV valve (was super gunked up), replaced oil pan gasket (was leaking), replaced cv joints(m) and axels(m), installed an atlas skid plate with oil drain hole from evolution imports, and I had the wheels balanced(m) and got it aligned(m).
Things remaining to look at are the timing belt, leaky injector pump, diff fluid, left rear window (won't roll up all the way), driver door switch panel (it's broken), and my HVAC system. Does not blow hot or cold, just outside air temp 24/7.
As far as the transmission goes, it's throwing a p0740 (torque converter clutch malfunction). I have pumped out a sample of fluid and it's pitch black, thick, and super saturated with various metal particles (it reacts like a ferrofluid when you pass a magnet over it). I topped it off with 1.5 bottles (24oz each, ~36oz total added) of Lucas oil stop slip (it was low) and haven't had any trouble out of it...but I'm sure using an impending rebuild.
I know I have much work to do and would like this car to make it to at least 500k miles. I know that's possible, but I'm gonna drive her till she's dead and good for parts.
My questions are these: is there anything I'm forgetting to do? And is there anyone with experience and VAG-COM near Elkmont Alabama that's willing to help change my timing belt? I'll buy the parts. Willing to travel to you if needed.
Edit: marked things mechanic did with (m), I did everything else myself.
