rowl
I was wondering what the guys that race the TDI's do? Surely they produce enough torque to break the mounts. They must have a fix........
Holy Moly ! How widespread is this problem with the 99.5> ALH's ? Looking at this pic http://www.fototime.com/BE96C7F58D96F1D/standard.jpg it seems VW didn't have a good handle on placing the flange ! Is the failure mechanism the flange breaking off the block in the first place or is it the bolts shearing/breaking ? If it's the latter, replacing the 3 lower bolts for a couple bucks sounds like a good insurance against a falling engine...UK_Pete said:Hello Wingnut,
Thanks for the useful info on fixing the broken engine mount. I have the same problem with my TDI and will try to do the fix. Can you say how well this fix (and any other similar ones) have lasted?
Depends. First time removal of mount can let you reuse the bolts. I have seen cars that have the same bolt after 4 timing belt changes. Bottom line as mentioned in other posts is that the bolt was tighten (overtorqued) than it is allowed for OR bolt is not tighten (undertorqued) when it should be allowing play room for the bolt to move which weakens the flange on the engine.thortdi said:Holy Moly ! How widespread is this problem with the 99.5> ALH's ? Looking at this pic http://www.fototime.com/BE96C7F58D96F1D/standard.jpg it seems VW didn't have a good handle on placing the flange ! Is the failure mechanism the flange breaking off the block in the first place or is it the bolts shearing/breaking ? If it's the latter, replacing the 3 lower bolts for a couple bucks sounds like a good insurance against a falling engine...
For my car it was the flange breaking off first. I know this because I found the broken part sitting in the tray when I did an oil change. I didn't worry too much at the time, as there was nothing apparently wrong with the car as the remaining two bolts were holding the engine. The full consequences revealed themselves later, when the bolts broke...thortdi said:Holy Moly ! How widespread is this problem with the 99.5> ALH's ? Looking at this pic http://www.fototime.com/BE96C7F58D96F1D/standard.jpg it seems VW didn't have a good handle on placing the flange ! Is the failure mechanism the flange breaking off the block in the first place or is it the bolts shearing/breaking ? If it's the latter, replacing the 3 lower bolts for a couple bucks sounds like a good insurance against a falling engine...
A picture or two:ninedee_golf_tdi said:Hard to determine the damage without a picture or two.
Small claims court, repair the car at your own expense and go to small claims court against the dealership for selling you a botched and band-aided used car off their lot ...which they will not honor a warranty against.FirstOrbit84 said:... Lemme know what you guys think I should do or what's possible, or if these pictures help at all. Thanks for your help.
The air conditioner pump is run off of the Timing belt?FirstOrbit84 said:Here my timing belt definately looks stripped but it seems to still have tension, either way I'll need a TB and Tensioner.
You'll find that the bracket design will have to be changed to fit a non-broken engine. The in-place tab will obstruct the top end and "push" the bracket away from a smooth contact with the block.wjbski said:Thankfully the replacement engine isn't missing the ear, so I'm going to fab up that bracket, run a longer bolt through the top hole and back up the bracket with a nut. Maybe it will be a cheap insurance policy.
thanks for the advice! I'll come up with a design that will work and post the finished product. Maybe it will help someone else from having their block get destroyed.MOGolf said:You'll find that the bracket design will have to be changed to fit a non-broken engine. The in-place tab will obstruct the top end and "push" the bracket away from a smooth contact with the block.
oh, sorry i'm still kinda new here. in that case, the timing belt seemed to be okay.MOGolf said:As whitedog points out, that is the serpentine belt, not the timing belt.
Before you go there remember you have a State Attorneys Office you can contact either by fax or phone. Many react upon these issues pretty seriously.FirstOrbit84 said:once they do (which im sure will happen), then i'll have to get lawyers involved
VIN: [FONT=Verdana, Arial, Helvetica, sans-serif]9BWBP61J624027851LOWRANGO said:...also if you post the vin, i can tell you what warranty work was done and the dealer that did it. you may find who did the work based on that(maybe not) but it worth a try... who ever repaired the car incorrectly is responsible...
Would love to hear about that one. Oh, Carfax currently has a class action law suit going on against them. But is nothing big. Still you might want to talk to the law firm sueing them. PM me for info if you desire it.LOWRANGO said:interesting first owner....
