Jcalvin1126
Hello all,
First of all I am a proud new owner of a 99 Golf TDI, and to say i enjoy it would be an understatement. However, I purchased it at a cheaper amount with the knowledge of it needing some repairs.
The first thing I noticed while driving was the coolant temp would not go above 80 degree F. Additionally the heater would never get warm. (sucks because its colder here right now). Additionally the coolant temp would flat line from time to time so I knew that it must be time to change the temp sensor.
After a lot of heart ache to find the blue version of the temp sensor, I finally got that replaced. I also replaced the thermostat for good measure, and attempted to burp the system as well as I could. (don't worry I only used g12). After looking around the engine I also noticed that the EGR valve is basically jimmy rigged to be wide open at all times, and the cut off switch was hanging there. Additionally the breather hose to the valve cover was removed, and blocked, and the vacuum lines plugged up. ( I have my work cut out for me)
So here is my problems, after fixing a majority of those issues. Now when I drive the temp will rise to right under 190 degrees F (just under middle). However, when I slow down and idle the temp will drop to just above the 3 bars at flat line. The heat will be warmer however not hot when at 190 degrees, and cold at idle.
My thoughts are I either have a massive air bubble screwing with my temp sensor, and potentially stuck within my heater core. Or, I need to replace the water pump. I plan on doing a 100k maintenance to it as the car has 240k miles, and I don't know when the last time it was done.
Any help will be much appreciated thank you!
( I am by no means a diesel mechanic, however I was a 6 year aviation mechanic for the U.S. Coast Guard, and a Back yard Gasser mechanic since I was 16. I am no master however, I am mechanically inclined so I can do the maintenance if you guys suggest something)
