runningallday
mk4 jetta TDI, 1999.5 manual, 155k miles
My battery light came on the other day, it was ridiculously hot and humid and I was stuck in stop-and-go traffic, so hot that the radiator fan turned on.
So at first, I just figured that the battery was just under stress or something? Since then, I've learned that the "battery" light is actually more an "alternator" light.
The battery soon died and would no longer start when I parked at home.
I took the battery off and charged it up - a day and a half later, I put it back in the car, expecting to be able to drive around until the battery died. But something strange happened.
The battery light stayed on - and then, once I revved the engine above 1500 rpm, all the gauges turned off and went to zero. I googled this, and they suggested the voltage given off by the alternator would be too high.
And so I checked this with my multimeter - and upon revving, the voltage across the battery went up to 17 volts really quickly. I haven't even turned the car on again since then.
I read online that "the voltage regulator can fail open or closed" - so it seems like at first, it failed closed, and now, for some reason, it failed open? I tried to read more about the brushes on the voltage regulator and the mechanism behind how they could fail - but couldn't find an explanation for this.
I checked the connections/wires/fuses on top of the battery - all very good. I checked the resistance of the wires between the alternator and the battery - both pretty low?
Unfortunately my car is not in a strategic place to have the alternator taken off (in my apartment parking lot), so I hope I can solve this problem without lifting up the car. So I decided that I'm going to try to replace the voltage regulator on the alternator, this looks doable (only 5 bolts from an awkward angle?). A new voltage regulator is coming in the mail later this week and I'll tear apart the car then.
Is "failure of the voltage regulator" a reasonable explanation for these symptoms?
Is there anything I missed, could it be anything else like some bad wiring?
Could anyone speculate on whether I'll end up needing to replace the entire alternator?
My first post - this community has helped me out so many times but previously I haven't posted anything - thanks everyone!
