tstdimk4
Well its a crappy rainy day here and i just got my build done late spring so i figured i would share what i have so far and can then update in the future. Heres a little info on my car
2001 RS jetta tdi 5speed. Bought it back in 08 with 189,000km on it came with eibach lowering springs, diesel power tuning box, evolution skid plate and motegi ff7 wheels (I know.. a little embarrasing but I thought they looked okay back then lol). Kept it like that till about 2010 and did an EGR delete, muffler delete, got some 337 edition BBS RCs, FK streetlines, GLI tails and Joey modded headlights.
Car was left like that till I started my build after my clutch went in Nov '12. The car is now only driven late april to late october. I would say it is now 95% done. And is as follows
Engine.
- stock ALH short block
- ported and polished head with 3 angle valve job, dual valve springs and nitride lifters
- arp head studs
- stage 2 cam
- race 520 injectors with stage 3 calibration
- 11mm injection pump
- PDlift pump
- PD150 intake manifold
- EGR delete (and egr cooler delete) replaced with race pipe
- CCV delete
- 4 Bar map
- custom FMIC with 2" piping
- custom "ram air intake pipe" to airbox (still has to pass snow screen filter first)
- custom OMI (2.5" pipe going from airbox to turbo
- GTB1756VK turbo on AFN manifold
- custom 2.5" turbo back exhaust
- custom KERMA tune
Drivetrain/suspension
- stock 5 speed (no LSD yet)
- Dieselgeek sigma 5 short shifter
- SB stage 2 endurance clutch with 21lb flywheel
- upgraded dogbone (BFI stage 1 mounts this winter probably)
- raxles
- stock brakes with slotted rotors and hawk HPS pads
- FK silver line coilovers with koni yellow rear shocks
- TT control arm bushings
- ECS rear centering plates
Exterior
- OEM votex front and rear bumpers
- R32 4 door rep side skirts (to come over the winter)
- boser hood. Welded on speedtech extension not CF or abs junk (to come over the winter)
- badgeless grille
- custom made retrofits with FXR bi-xenon and dual amber signals
- GLI trunk (debadged)
- GLI tails
- stubby antenna
- klutch republic SL14's 18x8.5 215/40/18 10mm spacer
18x9.5 225/40/18 3mm spacer
Interior
- stock leathers
- full GLI trim kit
- R line 5 speed knob and boot
- R32 pedals and dead plate
- pioneer appradio 2
- new south boost and EGT gauges
- IAT guage in custom vent pod over the headlight switch
- euro switch so I can run just my dual ambers at dawn or dusk
Here's some pics of the progress
Here's a recent pic of how the car currently sits
Engine.
- arp head studs
- stage 2 cam
- PDlift pump
- CCV delete
- 4 Bar map
- custom KERMA tune
- raxles
Exterior
- badgeless grille
- GLI tails
- stubby antenna
Interior
- stock leathers
- full GLI trim kit
