G60ING
- Joined
- Aug 5, 2001
- Location
- Alexandria, VA
- TDI
- No TDIs Currently, I have an R36 Corrado. I've had an ALH Corrado swap, AHU Corrado swap and 2003 TDI Jetta
I am planning to an a B5.5 VNT GT1749va turbo to my AHU. I already have the turbo, AFN manifold and now I want to get the misc parts so I can fit the turbo in the spring (yes a long build thread).
One of the best threads I have found for this upgrade is right here: http://forums.tdiclub.com/showthread.php?t=157345
First let me say that the 1749va is a small turbo upgrade. I'm looking for anywhere from 140-165whp without an IP upgrade and 170-180whp if I upgrade to an 11mm IP. I don't plan on upgrading the IP unless it begins to fail. An upgrade for this 1749va turbo is the BV43 turbo which is talked about here: http://forums.tdiclub.com/showthread.php?t=291947
Some of the reasons why I'm using this turbo is the price that I was able to get the manifold and turbo. Also this setup should clear the rear motormount & bracket.
I want to use as many factory parts as possible. I was able to get the Turbo NEW from VW for an excellent price, so good that I will have one spare on the shelf for the future (incase this one fails) and I'm rather frugal.
Here are some pictures of the 1749va compared to the GT15 (same as the kkk kO3):
The 1749va sits closer to the #2 cylinder then the KKK k03 which is almost centered between #2 & #3 cylinders so the AHU oil lines will be the wrong length but otherwise would connect to the 1749va.
My research on www.vagcat.com shows that the oil line part numbers are:
MK3 AFN Oil Return Line: 028 145 736 AB
MK3 AFN Oil Feed Line: 028 145 771 BE
Mk3 AFN Air Inlet Pipe (I think the AHU part will work) 1H0 129 965 N (1H0 129 965 P for Cold Weather Climate[PCV Heater])
Mk3 AFN Oil Line Bracket/retainer 028-145-859-J for AFN engine 1996 TDI Passat/Golf
Mk4 038-131-501-AN EGR Valve Replacement for 038-131-501-S on the AXR Engine- 2002 Golf TDI
Parts I have:
I have the 1749va
AFN Manifold
130 PD intake manifold and adapter *Installed*
PP764 *Installed*
mk4 N75 Valve
2" IC pipes *Installed*
Kerma Turbo Compressor Outlet adapter
AFN oil lines
AFN Turbo Inlet
Things I still need to get:
*downpipe, I was planning to build my own until I found a really good price on a NEW OEM downpipe and cat on the UKebay I'm just waiting for it to arrive any day now.
*ECU Modified
*adapter to the 2.25" cat back exhaust
*I might even try to get an EGR valve that works on my PD130 intake manifold so that can be fully functional. Time will tell. I know it might reduce power but I like the idea.
*Mandrel bend to adapt the IC pipe to the turbo outlet.
Finished list for others that want to put a b5.5 turbo on their Mk3/b4 1Z/AHU:
here are some pictures of my Engine bay and my AHU Corrado:
Oh and my upgrade timeline has been moved up because I made a mistake while doing my timing belt job and didn't remove my ratchet from the crank after making certain there was no interference after tightening up all the bolts during the timing belt job. So now I am going through the engine. The block will be getting new rings, the head is being rebuilt, the injectors balanced and the cam is being upgraded to a colt stage 2. I had wanted to rering the bolt at some point, I'm just frustrated that I'm forced to do it because of my mistake. At least its during the winter.
Link to a spreadsheet with part numbers, prices and sources
http://pics.tdiclub.com/data/500/Corrado_AHU_Rebuild_and_Upgrade_to_AFN_VNT_GT1749VA_Turbo_Costs_and_Parts.xls
Below are links that I'm storing here so I can begin compiling a decent AHU/1Z upgrade thread (I'm tired of searching for everything.)
AHU vs ALH discussion and includes a slight discussion of pistons:
http://forums.tdiclub.com/showthread.php?t=194801
http://forums.tdiclub.com/showthread.php?t=210044&highlight=pistons+ALH+AHU
http://forums.tdiclub.com/showthread.php?t=122581&highlight=pistons+ALH+AHU
Be careful when swapping injector pumps(see post 36):
http://forums.tdiclub.com/showthread.php?t=185550
Some of the AFN or VNT threads that I have found helpful for this swap:
http://forums.tdiclub.com/showthread.php?t=76707
http://forums.tdiclub.com/showthread.php?t=257753
http://forums.tdiclub.com/showthread.php?t=231874
AFN Vacuum line routing:
http://forums.tdiclub.com/showthread.php?t=291738
AFN Wiring Diagram:
AFN Wiring Diagram
Good thread explaining the flow for the various injectors:
http://forums.tdiclub.com/showthread.php?t=246968
AHU & 1Z Intake Manifold Threads:
http://forums.tdiclub.com/showthread.php?t=260729
http://forums.tdiclub.com/showthread.php?t=299857
http://forums.tdiclub.com/showthread.php?t=248172
PD manifold with an EGR for a Mk3/B4: http://forums.tdiclub.com/showthread.php?t=314011
Adjusting the EGR Opening Cycle (won't turn it off but it can decrease it):
http://www.tdiclub.com/TDIFAQ/TDiFAQ-7.html#j
Checking & Adjusting the VNT Actuator:
http://forums.tdiclub.com/showthread.php?t=312619
AHU/1Z Timing Belt Procedure:
http://www.tdiclub.com/articles/A3-TimingBelt
Adjusting Injection Quantity Technical Explanation of the Adjustment:
http://www.tdiclub.com/TDIFAQ/TDiFAQ-7.html#h
http://www.myturbodiesel.com/1000q/multi/IQ-adjust-hammer-mod-TDI.htm
Injection Pump Timing (the mechanical process of the adjustment):
Which way to advance or retard: http://www.tdiclub.com/TDIFAQ/TDiFAQ-7.html#k
Centering the pump in the mechanical adjustment range (do this before putting the belt on):http://forums.tdiclub.com/showthread.php?t=251065
When adjusting make certain you loosen all of the bolts: http://forums.tdiclub.com/showthread.php?t=256392
Injection Pump Timing Discussion of where the setting is best:
http://forums.tdiclub.com/showthread.php?t=240450
Finished Specs of my car:(September 2011)
Engine: 1.9L AHU from a 1998 Jetta with a Passat wiring harness
Brakes/Drivetrain: 5x100 Lug Conversion (Eurospec Sport Conversion Hubs), 11.3" Mk4 GTI rotors, 5x100 rear Rotors, SS lines, Mintex red pads
Suspension: H&R coilovers, Neuspeed 4 point rear strut bar (modified for Quick removal) R32 control arm bushings, New Strut Bearing Bushings, New rear shock bushings.
Wheels & Tires: 16" Audi TT wheels (Very Rare) that have been stripped of their paint and Polished. Yokohama Parada spec 2 Tires 205/40/16 Tires
Exterior: Stock Body work with 20+ years of minor wear and tear with the original paint. Tinted/Red taillights, clear side markers and European headlights. 90mm Front Euro Lip Lip. Passat Moonroof Conversion. The Moonroof interior panel has a grey cloth panel that matches the OEM headliner perfectly.
Interior: Stock Black Heated Leather with a TDI Passat instrument cluster with MFA 100% operational. Auber EGT, VDO boost & oil pressure gauges. European manual seatbelts. 337 Pedals
Audio/Visual: Late Mk3 Jetta Radio (matches the Rado's instrument lighting) No more amplified door speakers
Mileage
Drivetrain: Approx 175k, the engine had 115K miles when I started the swap.
The shell had 59k miles when I started
now at 120k
The car has an 15 gallon fuel tank and can get 48-52 mpg all day everyday with the 16s and driving it hard. 55-60 if I pamper it and try for economy. Why I think this car is so great? This is the car that I originally intended to build on my first TDI Corrado build, its all OEM like. Everything went together like it was built this way from the Factory.
The original build Thread:
http://forums.vwvortex.com/zerothread?id=3279771
Photo Album:
http://share.shutterfly.com/action/welcome?sid=8CZtXDdy5asRc
Parts I have:
I have the 1749va
AFN Manifold
PP764 *Installed*
mk4 N75 Valve
AFN oil lines
AFN Turbo Inlet
*ECU Modified
- AFN Oil Return Line: 028 145 736 AB
- AFN Oil Feed Line: 028 145 771 BE
- AFN Air Inlet Pipe (I think the AHU part will work) 1H0 129 965 N (1H0 129 965 P for Cold Weather Climate[PCV Heater])
- AFN Oil Line Bracket/retainer 028-145-859-J for AFN engine 1996 TDI Passat/Golf
- Exhaust/Turbo Manifold
- downpipe
- ECU Modified
- IC pipe to the turbo outlet modified
- N75 Valve
- Vacuum accumulator
- Reroute the vacuum lines
AFN Wiring Diagram:
AFN Wiring Diagram
- AHH TDI Long-Block NOS from VW
- AFN Exhaust Manifold
- GT1749VA turbo stock from a b5.5 passat tdi
- Stock Mk3 AFN Turbo Inlet Pipe and Oil Lines
- Stock B4 AFN TDI downpipe approx 2.25" od with cat
- Exhaust is currently a Techtonics 2.25" cat back with borla muffler (I would like to upgrade to a 2.5" Turbo back exhaust from Whitbread with V-brands, MangaFlow Cat and Borla Muffler)
- 130hp PD Intake manifold
- Custom EGR Valve
- 2" custom IC plumbing
- stock g60 Corrado Intercooler
- no lift pump
- stock 10mm AHU IP
- Bosio 1019 Injector nozzles and new NOS OEM injector bodies
- VNT ECU Conversion and Custom Tune www.malonetuning.com
- European Engine cover
- silicone hose connections
- Eco-Diesel Airbox
- ABA Windage Tray
- Pinned Crank Cog
Mileage
Photo Album:
