Anton,
That is really coming along...and looking sweet Very nice!
I do have some pics I can post...not too much...but here is some of whats going on. Just finally now getting the piston straightened around and doing all the details....but here you go...
The block, Cummins Beige in honor of the Cummins mechanical pump to be installed...
Respective pumps...
Need to get the head together and test fit, but I'm hoping that turning the A4 style sprocket backwards on the mounting up will align the cummins pump correctly. A mock up seems too, but I will that to have some material taken off the "front" side in order to clear the mounting bolts in the B4/A3 style bracket... reason why...cummins pump has a shorter nose than the TDI pumps do.... an AAZ pump pulley would work perfect, but I've been unable to source one.
Some of the details...this has been my last couple weeks while straightening out the pistons, sourcing them, etc...
The head after my R&R cleaning on my own last week...got it pretty good Now going to work on port matching it and rebuilding the internals..
and finally...a few other bits...the 10.1's that I'll be upgrading the Rabbit too (already running rear discs...) ... my intake manifold that I'm working on and inlet flange utilizing a modified G60 boost return valve...AWIC, and of course...a few pics of the Rabbit anxiously awaiting its new motor sporting its Centras
still need to go back and redo the euro bumpers and flares too...repaint, resto again...
Ah...can't wait Bigger and badder than ever
Joe
