My 98' Beetle TDI
sullyTDI
North Augusta, SC
2014 Jetta TDI
Mods:
Euro Switch
Euro Rear Fog
Fog Grill, Trim, and Lights
TDI Embles (Sides)
1.9 TDI Rear Emblem (VW Spain)
Side Repeater Lights
Added Hood Strut
Rear Spoiler
Mufflerectomy
Factory Wheels - from 2001 Beetle (No more hubcaps.....) 3/21/10
Maintenance:
Complete Timing Belt,Water Pump, Serp Belt Replacement
Complete Intake Cleaning with EGR Delete
Complete Vacume Line Replacement
New Bosch MAF
Fuel Filter - Upgraded to new style with thermo T
Performance:
Sprint 520 Injectors
Rocket Chip RC3 Tune 1/30/10
Sachs Clutch
Other:
Mann Oil Filter
Mann Air Filter with PreFilter
Fluid Types - Using:
Mobil 1 0w40 Euro Car Formula
Power Service Diesel Additive
OEM Lifetime Coolant
With Hub caps
Before:
With new 01' wheels​
After:
Bug Power
Munchin on some Green Stuff!
sullyTDI
North Augusta, SC
2014 Jetta TDI
Hood Strut
My 98' Had the good ole Prop Stick but made a few parts on the lathe and changed it out for the hood strut!
sullyTDI
North Augusta, SC
2014 Jetta TDI
Euro Fog - Rear
You might wonder Why??? Well, It saved my lunch and a few others in the mountains last year, in fog/clouds and all any of them could see in front of them was my Rear Fog....
BUGDOUT
Philadelphia
99 beetle
Very nice I just bought a 99 tdi beetle with 100k it's bone stock I'm gonna do the rc3 tune and I have some .205 nozzles for it how do you like the rc3 tune?I have no doubts I'll love it but I've been out of town slot and just haventhad the chance to schedule it with Jeff. Keep postingpics of your mods!
FlashT
LA
'98 NB - sold
SullyTDI,
Your car is absolutely immaculate. I'm wondering though, is your engine designated as an AGR?
And also, have you been having problems with the trunk latch motor when you open it with the key?
Just one final question: What is your engine's output designation code (it should be on the build sheet)?
I hope all goes well with your car.
robinorobino
south east FL
2000 Beetle TDI
sullyTDI said:
Mods:
Euro Switch
Euro Rear Fog
TDI Embles (Sides)
Added Hood Strut
Rear Spoiler
Mufflerectomy
Maintenance:
New Bosch MAF
Performance:
Sachs Clutch
Other:
Mann Oil Filter
With Hub caps
Before:
After:
Bug Power
are you getting a small shake when coming to a stop...since blocking the EGR?
i'm getting a small studder when coming to a stop which doesn't seem to raise or lower the rpm's at all, it's a studder that comes on only as i'm approaching a stop sign or red light.
rackaracka
Monroe, NJ
The small shudder you get when coming to a stop, which completely smooths out as soon as you stop rolling - That is a slow down shudder (SDS) and is related to over fueling. You can raise your IQ on your injection pump to reduce fueling and sometimes eliminate this nuisance. I occassionally have it bad with my 11MM pump and PP520s. I've been led to believe that it can also be reduced or eliminated with the right tune.
kcfoxie
Raleigh, NC
'12 6-spd JSW
Thanks guys, I thought this studder was from a bad wheel bearing and it turns out that a tune may be the solution (they fix everything!).
Bob_Fout
Oil Wanker
Indiana
A stock TDI should not have slow-down-shudder unless someone really fubar'd the IQ.
kcfoxie
Raleigh, NC
'12 6-spd JSW
My EGR is blocked off by the PO. It was "dealer maintained" and the belt's due in 25k miles... so Buddah only knows.
robinorobino
south east FL
2000 Beetle TDI
even with 520 sprints and egr blocked off?
what is the shudder anyway? The rpm doesn't fluctuate, yet the motor shakes and shudders
Bob_Fout
Oil Wanker
Indiana
Hm. Blocking off the EGR with stock tuning does strange things to the ECU. Sprint 520s alone should not cause it.
I've never experienced slow-down-shudder, but I've heard it's some engine shaking at at low RPMs when decelerating.
