GTiTDi
TDIClub Enthusiast, Macht Schnell! Vendor , w/Busi
- Joined
- Oct 18, 2010
- TDI
- '91 GTI CJAA swap,'02 Jetta wagon ALH swap, '03 GTI 1.8T rally car, '03 Sprinter 3500
Thank you, it has been a lot of work restoring this car, I have a lot to do, it wasn't on the road for 10 years. I still think I am going to try to find a mk3 tdi cluster or a A2 TD cluster so I have the correct tach range and a proper glow plug light. I kept the A2 cluster in my Jetta ABA 2.0, just never hooked up the VSS lead, I can't remember if the 86 had the sensor..I still have to set that up because it cuts out a 5,000rpms in 4th and 5th. you can wire any of the unused LED's on the A2 cluster to be a glow light or check engine light, on mine I used the "OXS" light that was for the O2 sensor replacement interval system that I yanked out when I did the swap.
