Thanks. I'm not a fan of wagons, so if it was, I never would have bought it.What an amazing change...too bad it wasn't the rare wagon 1996. Still an amazing transformation!
Will your cool BBS RJ wheels accommodate a big brake conversion?Placed the order for my pp764's today, my calipers also arrived. I should have the rest of my brake parts early next week.
They should, the rotors are from a 92 corrado g60, same as the wheels. Ther calipers are huge compared to the crappy factory ones. I'll do a test fit tomorrow and post the results. I need to find a decent set of 225/50/15, my 185/60/15 will not hold up to the abuse very long.Will your cool BBS RJ wheels accommodate a big brake conversion?
The tune is requesting 22psi (which is 2.5 bar absolute). I still have the stock 2.5 bar map, but seeing the gt1749va has an effective limit of 22psi, this works fine. The tune is acting correctly, raising duty cycle of n75 during overboost, but something in my vacuum or mechanical boost regulation is not working correctly. I'll take the mighty vac out now and see when it starts and stops movement. I'll also monitor vacuum levels at the actuator.The tune's requested boost is 25 psi? That is ~3.4 bar absolute. You have a 4 bar sensor installed?
When you lengthened the rod, what are the vacuums reported for when it start moving and when it stops? For my 1756, I have it start at ~3 inHg and stop ~12.5 inHg.
What are you doing for the brake lines? Where are you purchasing the calipers? Are you changing the master cylinder at some point?I just did some research on improving the braking on the B4's and read this article: http://www.myturbodiesel.com/1000q/a3b4/girling-g60-brake-caliper-swap.htm
That lead to some shopping (FYI, these are loaded calipers and include the carriers):
and two of these: http://www.amazon.com/Raybestos-96122R-Professional-Grade-Brake/dp/rebates/B000JZPK6K
I like the 5 lug swap, but I'm happy with my BBS wheels that I got very cheap, and in order to get the level of braking I'm going to get with the setup described above, I'd still need to upgrade to dual piston calipers, a bigger master cylinder, and larger rotors. I'll be sure to document the install. FYI, this brake project set me back about $280. I guess that means I've got about $2500 in the car now. Will get close to $3000 with the new nozzles.
for brake lines, Im going to use 89 200 Quattro hoses, they are rubber from shock to caliper. I got the calipers from rock auto (shopping cart image), I'm also using a master cylinder from a 5000 turbo quattro (it is listed in shopping cart image as well).What are you doing for the brake lines? Where are you purchasing the calipers? Are you changing the master cylinder at some point?
Well, this setup with the dual piston calipers uses the 11" corrado g60 rotors also, so it is definitely more expensive, but the braking power should be substantially more. I think the total cost is about $250 with all new parts. My old calipers were getting a bit crusty anyway and I'm really not impressed with current braking.I'm curious if the dual piston calipers have an advantage over 11" brakes.
You wouldn't have needed the m/c and hoses, but you would have needed new rotors. Not sure which would have been more expensive.
-Todd
Yeah, I haven't received my rotors yet, those pics were just showing the calipers bolted on and wheels clearing the calipers.Oh... your pic of the stock rotors led me to believe the set up was 10.1".
I'm stripping a B4 with a G60 11" swap, so I'll likely toss that on my B4. Curious what it'll feel like.
-Todd
Thanks for the info, I'll check it out.You said your actuator is setup to stop at 14-15 in Hg. Pull a log, don't have to post it, and check your duty cycle in Group 11 please. If you've under 60-65% at 4000 RPM, then you need to shoten your rod length a bit. This will cause boost to come on sooner and can help with smoke as well.
You think starting with 1 turn is a good place to begin?lengthen
