Lightflyer1
Here is my 2003 New Beetle GLS TDI as it sat for sale with a leaky IP and TB issue of tensioner installed incorrectly. Head/valve damage. Bought for $1200.
First bill for repairs on 9/2/2015:
Make/model 03 Beetle
mile 157,450
Labor:
Description: Charge:
Install injection pump seal kit $ 312.11
Install timing belt kit $ 385.00
R&I cylinderhead (6hrs@$90/hr) $ 540.00
Install lower radiator hose and repair expansion tank hose $ 45.00
Install inner drive axle boot, right and left (1.5hr/side) $ 270.00
Install fan set $ 90.00
Install glow plug harness $ 90.00
install oil pan $ 90.00
Total Labor: $ 1,822.11
Outside services:
Brooks Elliot Machine Shop head repair service exchange $ 280.00
Brooks Elliot Machine shop intake cleaning service exchange $ 50.00
Total: $ 330.00
Parts:
Description: Unit Price: Total Price:
1 Bosch IP seal kit $ 21.00 $ 21.00
1 fuel return line set $ 5.00 $ 5.00
1 dieselgeek.com ALH timing belt kit with $ 340.00 $ 340.00
timing belt, tensioner, water pump, 3 rollers
vacuum pump seal and serpentine belt
1 cylinder head gasket, 2 hole $ 23.40 $ 23.40
10 cylinder head bolt $ 1.26 $ 12.60
1 intake manifold gasket $ 2.00 $ 2.00
1 exhaust manifold gasket $ 9.95 $ 9.95
1 down pipe gasket $ 3.00 $ 3.00
1 EGR to intake o-ring, viton $ 5.00 $ 5.00
3 EGR pipe gasket, metal $ 3.95 $ 11.85
1 EGR pipe gasket, paper $ 3.80 $ 3.80
4 injector crush washer $ 0.90 $ 3.60
1 turbo oil return line gasket $ 4.00 $ 4.00
1 camshaft $ 100.05 $ 100.05
8 cam follower, INA $ 9.42 $ 75.36
1 camshaft oil seal, PTFE $ 10.00 $ 10.00
2 intake valve $ 13.00 $ 26.00
1 water outlet flange o-ring $ 5.00 $ 5.00
1 lower radiator hose $ 36.18 $ 36.18
1 hose repair union, repair hose and clamps $ 11.00 $ 11.00
2 drive axle boot, inner $ 20.00 $ 40.00
4.5 Fuchs Titan Supersyn 5w40 motor oil, liter $ 6.66 $ 29.97
1 oil filter $ 8.00 $ 8.00
1 glow plug harness $ 102.00 $ 102.00
1 cooling fan, left $ 66.37 $ 66.37
1 cooling fan, right $ 68.27 $ 68.27
1 oil pan $ 88.00 $ 88.00
5 G12 coolant, mixed 50:50 distilled H2O, liter $ 3.00 $ 15.00
1 coolant expansion tank $ 18.24 $ 18.24
subtotal $ 1,144.64
Tax: $ 94.43
Part Total: $ 1,239.07
Invoice Total: $ 3,391.18
Second bill for oil pan incidinet on 9/9/2015:
mile 157, 676
Labor:
Install oil pan $ 90.00
Install dieselgeek panzer plate w/ FMJ $ 60.00
Total Labor: $ 150.00
Parts:
1 dieselgeek.com Panzer Plate kit $ 275.00 $ 275.00
1 side dkirt FMJ set $ 99.00 $ 99.00
4 Fuchs Titan Supersyn 5w40 motor oil, liter $ 6.66 $ 26.64
subtotal $ 488.64
Tax: $ 40.31
Part Total: $ 528.95
Invoice Total: $ 678.95
Car wasn't running so I bought a clutch set just in case:
$33.93 Volkswagen 02J 141 719 C, Clutch Release Arm
$34.33 Victor Reinz 67750 Rear Main Seal
$187.57 LuK 17-050 Clutch Set
$22.50 Axle Shaft Seals (2)
$12.00 CV Joint Bolt (12)
$1.75 Retaining Spring for Clutch Release Lever Pivot
$85.90 Clutch Slave Cylinder (A4)
$9.30 Audi Vw Mercedes Double Din Radio Removal Key Tool (2 Pair)
$72.97 New fog light set Amazon by AutoHalo.
$58 Dieselgeek Beetlebrace door handle reinforcement
$200 Maaco painting of front grill parts
$50 Bentley Beetle Manual
http://www.expressoemparts.com/
Part Number Part Name Price Quantity Total
1C0-805-903-G-GRU LOWER PANEL $105.21 1 $105.21
1C0-807-681-E-01C LOWER GRILLE $39.71 1 $39.71
1C0-807-341-A-GRU COUPLING $57.12 1 $57.12
Subtotal: $202.04
Shipping (UPS - Ground): $60.24
Handling: $2.75
Total: $265.03
Part Number Part Name Price Qty Total
1C0-868-107-B-FYZ DOOR TRIM PANEL, LEFT $350.03 1 $350.03
1C0-868-108-B-FYZ DOOR TRIM PANEL, RIGHT $350.03 1 $350.03
1C1-857-628-B-62J GRIP HANDLE CAP, RIGHT $4.55 1 $4.55
1C1-857-627-C-62J GRIP HANDLE CAP, LEFT $4.55 1 $4.55
1C0-858-069-AA-XNX CENTER BEZEL $165.12 1 $165.12
1C1-880-882-E-3SG GLOVE BOX DOOR $229.72 1 $229.72
Subtotal: $1,104.00
Shipping: $80.61
Handling: $2.75
Total: $1,187.36
Total so far: $7693.27
Starting to look like new!
mile 157,450
Labor:
Outside services:
Total: $ 330.00
Parts:
subtotal $ 1,144.64
Tax: $ 94.43
mile 157, 676
Labor:
Parts:
subtotal $ 488.64
Tax: $ 40.31
Subtotal: $202.04
Handling: $2.75
Total: $265.03
Subtotal: $1,104.00
Shipping: $80.61
Handling: $2.75
Total: $1,187.36
