multiple codes after backup camera and trailer lights installed - MIL and Flashing glow plug - Need help!!
Drclaw
ME
2014 Jetta Sportwagen
Hey everyone, so for the last few days I was working on the car to install a 4 pin trailer light connections and a new Aux backup camera to pair with my RDC 330 head unit that Ive had for a while. Everything went well and I drove the car about 50 miles round trip with back roads and higway, no issues, except for I lost my cruise control function somehow. I thought that I may have screwed something up when I was playing with some VCDS coding that I 2x checked after I had the battery disconnected, it seemed like I lost some of my features I previously installed. This no cruise control is where the problem starts. I 2x checked some VCDS settings and didnt see anything so I thought maybe it was the fuse location I tapped off of for the backup camera or the location on the battery box I used for the trailer light power supply. For the backup camera I used one of those piggyback fuse connectors and hooked up to fuse 5 or 6 on the interior driver side fuse location. For the trailer lights , I originally hooked up to one of those other power locations on the main fuse box under the hood. Since I was having issues, I thought maybe I was having some electrical gremlins so last night changed that connection to the main battery terminal. As I was doing that, I dropped a 10mm socket, I thought it went to the plastic cover but it was getting dark and went inside with the intent to find it this morning. Before I called it quits last night, I backed up in the driveway at about 5mph and hit the brakes, then forward and same thing to see if I could get the socket to spit out. Nothing. So this morning, I took the bottom plastic cover off and couldn't find it. I went all around the engine bay with a flashlight and still cant find it. I 3x checked the driveway and grass, still cant find it. The 10mm socket is AWOL. So, im like ok whatever lets just move on and ill eventually find it. I tried changing the engine coding to "turn on cruise control" using the same thing as this video Engine-->coding ii--> change to 11463 and nothing.
I also did this last night and didnt work but also didnt turn the car on for more than that back and forth in the driveway stunt i mentioned above. So this morning , after I change the engine code to 11463 again, I figure Ill go for a test drive and see if it changes. I turn the car on and it doesnt sound right, something is off, I pop the hood and it sounds like a vaccum leak of some type. This is my first TDI so Im not familiar with all the noises but i can hear something. I get back in the car and I have a flashing glow plug and can smell a little gas. I check codes and get a 000175 as well as some others. Ive cleared them several times and nothing changes. I have no turbo and my brake pad feels different too, like its very hard to press. Not sure what to do now but Im pretty annoyed with myself. one other thing to note is that I had my DPF replaced about 500 miles ago by a dealer. When I was installing my cable runs for the power to the trailer lights I noticed that they two bolts at the bottom of the DPF housing that mount into an aluminum section under the engine where backed out quite a bit. I tightened them up but made me wonder what else the dealership may have not put back together correctly.
Any ideas? Sorry for the convoluted post, there is a lot here and I am not sure If I did something via electrical issues (the trailer wires were tapped and the backup camera were soldered) I only messed with the tail light connectors to tee into, nothing else was tapped) Or if my socket somehow got lodged in the engine bay somewhere and is now F'ing my turbo up.
codes from vcds attached below
Saturday,03,September,2022,18:03:26:39469
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 22.3.1.4 (x64)
Data version: 20220407 DS337.0
www.Ross-Tech.com
VIN: 3VWML7AJXEM625063 License Plate:
Mileage: 113730km-70668mi Repair Order:
Chassis Type: AJ-VW36 (7N0)
Scan: 01 03 05 08 09 15 16 17 19 25 2B 2E 37 42 44 46 4F 52 56 62
72
VIN: 3VWML7AJXEM625063 Mileage: 113730km-70668miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
2E-Media Player 3 -- Status: Cannot be reached 1100
37-Navigation -- Status: Cannot be reached 1100
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (CJA) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 997 030 D HW: 03L 907 309 AA
Component: R4 2.0l TDI G000SG 9983
Revision: 12H16--- Serial number:
Coding: 0050072
Shop #: WSC 21248 005 1048576
VCID: 2F6DD2E9BE8761F766-807A
VINID: 0E69DD70745AA157460850060CB6B302AA
2 Faults Found:
049682 - Steering Column Control Module
U0212 - 001 - No Communications - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 6
Fault Frequency: 8
Reset counter: 255
Mileage: 113602 km
Time Indication: 0
Date: 2017.01.23
Time: 05:11:58
Freeze Frame:
RPM: 828 /min
Speed: 0.0 km/h
Temperature: 19.8°C
Voltage: 13.68 V
Bin. Bits: 00000000
Torque: 0.0 Nm
Temperature: 54.0°C
006470 - Control Module 1 for Coolant Fan
P1946 - 000 - Defective - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 7
Reset counter: 255
Mileage: 113702 km
Time Indication: 0
Date: 2017.01.23
Time: 23:08:53
Freeze Frame:
RPM: 1610 /min
Speed: 95.0 km/h
Temperature: 19.8°C
Temperature: 93.6°C
Temperature: 15.3°C
Lambda: 86.8 %
Lambda: 0.0 %
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BM HW: 1K0 907 379 BM
Component: ESP MK60EC1 H46 0164
Revision: 00H46001
Coding: 114B600C492400FF880B06EA921C0042A5000022
Shop #: WSC 00066 000 00000
VCID: 7EF33FADE96D587FBD-802A
No fault code found.
Address 05: Acc/Start Auth. (J518) Labels:| 5K0-959-434.clb
Part No SW: 5K0 959 434 B HW: 5K0 959 434
Component: VWKESSYPQ35GP 086 1101
Revision: 00086000 Serial number: 0329826876
Coding: 030C0C
ASAM Dataset: EV_KESSYPQ35G A02013
ROD: EV_KESSYPQ35G_A02_VW32.rod
VCID: 3467DD859FA1422F1B-8060
Address 08: Auto HVAC (J301) Labels:| 3C8-907-336.clb
Part No SW: 7N0 907 426 CA HW: 7N0 907 426 CA
Component: AC Manuell H20 0606
Revision: 00001002
Coding: 0010002002
Shop #: WSC 00066 000 00119
ASAM Dataset: EV_ACManueBHBVW36X A01010
ROD: EV_ACManueBHBVW36X_VW36.rod
VCID: 75E12081D45B1B27EC-8020
1 Fault Found:
13701888 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 7
Reset counter: 125
Mileage: 113650 km
Date: 2022.09.02
Time: 08:51:14
Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
Part No SW: 5K0 937 084 N HW: 5K0 937 084 L
Component: BCM PQ35 B 122 1184
Revision: BG122001
Coding: EF380EBF84393EC4408800C1740000444F000086570D05B064802020A040
Shop #: WSC 53964 001 104857
VCID: 3D71F8A1A4EB8367E4-8068
Subsystem 1 - Part No: 5K1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 27051 26 0512
Coding: 009795
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 5C0 959 655 M HW: 5C0 959 655 M
Component: AirbagVW10G 014 0726
Serial number: 003L4R035PWY
Coding: 00004E42
Shop #: WSC 00066 790 00185
ASAM Dataset: EV_AirbaVW10SMEVW360 001026
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3C77F5A5B7F18A6FD3-8068
Seat occupied recognition:
Subsystem 1 - Part No SW: 1KM 959 339 B HW: 1KM 959 339 B
Component: BF-Gewichtss. 006 0001
Serial number: ---0000R--0000AZM000
Crash sensor for side airbag: driver side:
Subsystem 2 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Component: S.Sens.Fahr.V H02 ----
Serial number: 3572MSME6E071B43ZZZ$
Front Passenger's Side Airbag Crash Sensor:
Subsystem 3 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Component: S.Sens.Beif.V H02 ----
Serial number: 3582MSME59051B43ZZZW
Rear Side Airbag Crash Sensor (on driver's side):
Component: S.Sens.Fahr.H --- ----
Serial number: 3511HSME7D303830ZZZI
Passenger side rear thorax airbag crash sensor:
Component: S.Sens.Beif.H --- ----
Serial number: 3521HSME04003930ZZZ1
Crash sensor for front airbag: driver side:
Component: F.Sens.Fahr --- ----
Serial number: 35527SME23524430ZZZ%
Crash sensor for front airbag: front passenger side:
Component: F.Sens.Beif --- ----
Serial number: 35627SME19524430ZZZ5
Address 16: Steering wheel (J527) Labels:| 5K0-953-569.clb
Part No SW: 5K0 953 521 DT HW: 5K0 953 569 AH
Component: LENKS.MODUL 016 0140
Revision: FF010042 Serial number: 20140414200832
Coding: 1092140000
ASAM Dataset: EV_SMLSNGVOLWSXS A01004
ROD: EV_SMLSNGVOLWS.rod
VCID: 0109445190932787C0-8054
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H31 0037
Coding: 820000
1 Fault Found:
147464 - Terminal 15
B1148 29 [009] - Signal Implausible
Freeze Frame:
Fault Priority: 6
Fault Frequency: 14
Reset counter: 85
Mileage: 113602 km
Date: 2022.09.02
Time: 05:06:32
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 5K0 920 973 G HW: 5K0 920 973 G
Component: KOMBI H04 0811
Serial number: 00000000000000
Coding: 271D01
Shop #: WSC 00066 123 00119
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04721
ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod
VCID: 3561E08194DB5B272C-8060
Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 AM HW: 7N0 907 530 AM
Component: J533 Gateway H55 1642
Revision: H55 Serial number: 24051403001240
Coding: 352002
VCID: 7BF536B9FA7F4D579A-802E
2 Faults Found:
01300 - Control Module for Navigation with CD-Rom (J401)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 81
Mileage: 113602 km
Time Indication: 0
Date: 2017.01.23
Time: 05:06:39
03272 - Control Module for Audio Interface
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 81
Mileage: 113602 km
Time Indication: 0
Date: 2017.01.23
Time: 05:06:39
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H04 0811
Serial number:
Coding: 000007
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
VCID: 6ADB03FD8DE5C4DF71-803E
Address 2B: Steer. Col. Lock (J764) Labels:* 5K0-905-861.clb
Part No SW: 5K0 905 861 C HW: 5K0 905 861 C
Component: ELV-PQ35 H21 0240
Revision: 00000000 Serial number: 14000087217005
Coding: 4100000000000000
Shop #: WSC 00066 790 50316
ASAM Dataset: EV_ELVMarquMPVW36X A01001
ROD: EV_ELVMarquMPVW36X.rod
VCID: 306FD1956BB97E0F7F-8064
Address 2E: Media Player 3
Cannot be reached
Address 37: Navigation
Cannot be reached
Address 42: Door Elect, Driver (J386) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 561 959 701 HW: 3C0 959 793 B
Component: TUER-SG FT 002 0501
Revision: 13110009 Serial number: 0008391179
Coding: 0004B5
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_TSGFPQ35BRFVW46X A04001
ROD: EV_TSGFPQ35BRFVW46X_VW36.rod
VCID: 5BB5563952BFAD57FA-800E
Slave Driver:
Subsystem 1 - Part No SW: 3C0 959 703 C HW: 3C0 959 795 D Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 009 1509
Serial number: 00000008702054
Coding: 000490
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 70 3501
Revision: 00H22000
Shop #: WSC 02069 000 90108
VCID: 3979ECB170C3BF47C8-806C
Address 4F: Centr. Electr. II (J520) Labels:. 1K0-907-532.clb
Part No SW: 7N0 907 532 HW: 7N0 907 530 AM
Component: EZE_2 H55 1642
Coding: 050B0500
VCID: 6FED12E9BE0721F726-803A
Subsystem 1 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H05 0220
Serial number: 0123456789ABCDEFGHIJ
Subsystem 2 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J394EE20SKB13 H05 0220
Address 52: Door Elect, Pass. (J387) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 561 959 702 HW: 3C0 959 792 B
Component: TUER-SG BT 002 0501
Revision: 15110009 Serial number: 0008394484
Coding: 0004B4
ASAM Dataset: EV_TSGBPQ35BRFVW46X A04001
ROD: EV_TSGBPQ35BRFVW46X_VW36.rod
VCID: 5CB7552557B1AA6FF3-8008
Slave Passenger:
Subsystem 1 - Part No SW: 3C0 959 704 C HW: 3C0 959 794 D Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 009 1509
Serial number: 00000008680883
Coding: 000490
Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 6RF 035 187 F HW: 6RD 035 187 B
Component: Radio 566 Y520
Revision: -------- Serial number: VWZZZ4H6290655
Coding: 0E000440040005
Shop #: WSC 127395 840 08317
VCID: 4C97A565EF513AEF63-8018
End-------------------------(Elapsed Time: 03:04)--------------------------
Sunday,04,September,2022,10:26:26:39469
www.Ross-Tech.com
72
03-ABS Brakes -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
Coding: 0050072
2 Faults Found:
000175 - Actuator Module for Turbocharger 1
P00AF - 001 - Stuck - MIL ON
Freeze Frame:
Fault Status: 11100001
Fault Priority: 2
Fault Frequency: 3
Reset counter: 255
Mileage: 113737 km
Time Indication: 0
Date: 2017.01.25
Time: 15:31:02
Freeze Frame:
RPM: 851 /min
Speed: 0.0 km/h
Load: 0.0 %
Load: 100.0 %
Lambda: 10.3 %
Pressure: 992.2 mbar
Temperature: 19.8°C
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 255
Mileage: 113737 km
Time Indication: 0
Date: 2017.01.25
Time: 15:35:54
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Temperature: 18.0°C
Voltage: 12.16 V
Bin. Bits: 00000000
Torque: 219.0 Nm
Temperature: 36.0°C
Readiness: 1 1 0 1 1
Revision: 00H46001
1 Fault Found:
01325 - Control Module for Tire Pressure Monitoring (J502)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 125
Mileage: 113737 km
Time Indication: 0
Date: 2017.01.25
Time: 00:01:19
Freeze Frame:
Count: 2
Count: 4
Count: 4608
Count: 16390
Count: 50944
Count: 0
Count: 0
Count: 0
Coding: 030C0C
Revision: 00001002
Coding: 0010002002
1 Fault Found:
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 7
Reset counter: 125
Mileage: 113650 km
Date: 2022.09.03
Time: 08:51:14
Revision: BG122001
Coding: 009795
Coding: 00004E42
Coding: 1092140000
Coding: 820000
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 28
Reset counter: 85
Mileage: 113602 km
Date: 2022.09.03
Time: 05:06:32
Coding: 271D01
Coding: 352002
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 81
Mileage: 113602 km
Time Indication: 0
Date: 2017.01.24
Time: 05:06:39
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 81
Mileage: 113602 km
Time Indication: 0
Date: 2017.01.24
Time: 05:06:39
Serial number:
Coding: 000007
Cannot be reached
Cannot be reached
Coding: 0004B5
Slave Driver:
Coding: 000490
Revision: 00H22000
Coding: 050B0500
Coding: 0004B4
Slave Passenger:
Coding: 000490
1 Fault Found:
02873 - Control Module for Back-Up Camera (J772)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 85
Mileage: 113737 km
Time Indication: 0
Date: 2017.01.25
Time: 15:30:33
End-------------------------(Elapsed Time: 03:06)--------------------------
Drclaw
ME
I had to call it quits this morning but I guess I should just disconnect the power for the fuse and the trailer lights and roll back ant vcds settings and go from there. Any other immediate thoughts? Troubleshooting that 000175 codes seems pretty extensive and I don't have all the tools to do so (vac checker etc).
DrGERTol
NW OH
2011 Golf Variant (JSW) 6MT
What back-up camera ? Your RCD-330 seems to be looking for J772 on the CANBUS.
Your CAN Gateway (Address 19) is still looking for the old RNS-315/510 and music interface module: you should fix that in the installation list.
Re DTC 01325 - Control Module for Tire Pressure Monitoring (J502), our wagens don't used J502, is this checked in Address 19?
Re the vacuum leak noise & brake pedal feel, make sure you didn't dislodge a vacuum hose when you routed the trailer power cable from the engine compartment through the firewall. I think I would have done this with a full-size add-a-fuse to one of the switched positions in Fuse Panel C:
Here, positions 5 & 6 in the top row are new circuits I added for a few mods (auto dimming mirror w compass, wireless charging dock, back-up camera, etc.).
If you really want +12V for the trailer to come from the engine compartment, you should pull it from Fuse Panel A (the unused connection next to the starter battery cable):
Here, I added a CTEK charging cable connection for running a battery maintainer when we're on vacation or we get a polar vortex in the winter; currently also has power for simple front fog lights controlled by a relay. --g
Drclaw
ME
Thanks for the thoughts @DrGERTol , you've helped me in the past as well.
The backup camera I got was this one from AliExpress
US $31.99 20%OFF | RCA Rear View Camera with Trunk Switch MIB RCD330 Plus HD Wide Angle Parking Reverse Camera For VW Golf 5/6 Passat B6 B7 TIGUAN
https://a.aliexpress.com/_m0Cf4Jm I'm pretty sure I've had those codes re: to the radio since I installed it and just ignored them.
The tpms is prob vcds related and I think I goofed that. What module is that under? Brakes or central electronics?
The vacuum leak/brake issue could def be something I dislodged. The part that doesn't make sense is that I drove the car for 50 miles after I finished the backup camera and trailer lights and had zero issues. They didn't start until this morning after I changed the power hookup for the trailer lights and dropped that 10mm socket. Do you think that could have gotten sucked up into an air intake somehow? Or worse into the turbo? I opened my engine air filter box and nothing in there.
Any thoughts on that 000175 code?
DrGERTol
NW OH
The back-up camera looks like a simple composite video device without controller J772. The DTC is likely related to incorrect RCD-330 long coding.
The TPMS DTC is under ABS/Brakes, also possibly related to incorrect long coding.
The 0175 DTC has the same mileage as the steering wheel communication DTC. You sure you didn't undo or disturb some electrical connectors in the engine compartment while (re)routing power to the start battery (+) terminal ? I'd recommend you move that back over to Fuse Panel A (or C, as noted earlier). I think it nearly impossible that a 10mm socket can find its way into the intake air system (unless it was open at the time). --g
Drclaw
ME
I originally had the trailer lights power going to the post next to your ctek connection (fuse panel A) I do have that extra one available with nothing on it but didn't have a bolt on it so I put it on the one next to it (second from left in the last picture you show) but because of the loss of cruise control I tried putting it straight to the + battery terminal which is where it currently is.
I'm not sure why the code readout is like that, I think I ccp'd indirectly and grabbed two separate reads my driveway between checking and clearing engine codes.
Also when you say possible related to incorrect long coding, is that within that module or in general somewhere?
Drclaw
ME
@Drclaw : Fuse Panel A reference here: https://www.vwvortex.com/threads/gov-fuse-panel-reference-for-my2011.9501257/
Seems to me the position with the least "risk" would be A6 on the front panel. Position A2 is related to power steering systems. The post next to A7 is direct to the starter battery (+) terminal. --g
Thanks for sharing that. Very useful. I originally had it on the 7th from the right, with the larger gauge wire on it. See pic here.
I think I said second from the left earlier but actually meant second from the right. You used that open spot all the way on the right fpr your battery tender, correct?
Wilkins
British Columbia
I took my trailer power from the ‘stock’ euro trailer connection on fuse panel C. I don’t have the car available to check right now but I think it was 16. 10 A fuse has worked fine for several years and I do a lot of towing.
Drclaw
ME
@DrGERTol I think I figured out what is going on, at least part of it.
I got back home this afternoon and pulled the battery out, battery tray and air filter box so I could get a better look at what's going on. I also jacked the front end back up again and pulled the bottom plastic tray from under the engine.
I found the 10mm socket. It was in the driver side fog well cavity area , so that's good and can rule that out from anything.
While I had everything out, I checked that trailer wiring run, nothing out of the ordinary. I did pull it back through and routed with less interference but same general path. When I moved the trailer power connection over to the main + battery terminal I put on a smaller ring terminal because the original one I had on it was too large, and when I disconnected that from the battery terminal in prep to pull the battery out, that smaller ring terminal that I put on last night slipped off, so it wasn't on there very good, for whatever that is worth. I put a new one on, 2x checked it was on their good and tight and move it over to Fuse panel A, slot A6.
This morning is where I caused the 000175 and Brake problem, at least I think so. As I was inspecting around the engine for that 10mm socket, I pulled my engine cover off, the vanity one with the foam pad on the under side. I happened to notice that the front driver side corner foam was bent under itself and smashed down like that, it looked it had been like that for some time, as it didn't have a lot of memory recall left in it and want to unflap. I unflapped it and put the cover back on. When I did this I think I broke the brake booster to vaccum pump line line, pic shown here, imgur not working for me for some reason , but this is the part. It broke on that nipple coming off the brake booster. https://www.idparts.com/vacuum-pump-brake-booster-line-cbeacjaackra-561612041c-p-13939.html
I didnt realize it at the time but now that I found this broken line and 2x checked where it is relative to that foam corner, its right there. I bet I unbent the foam and snapped the line.
I was able to pull out the compression fitting, and slip the tubing back over and throw a zip tie on it for now. cleared the codes and started the car and sounded much better. havnet gone for a test drive yet, getting in troubel with the wife for spending too much time on the car. After dinner I will. I think I am back to where I was the day before and need to figure out this cruise control issue, i did see something about the trailer module causing this error so it could be realted to that.
thanks for all the help. if/when the imgur photos upload, ill share those.
DrGERTol
NW OH
@Drclaw : Add images here directly with the "Media > Add Media" drop-down in the site menu bar, above. Then, add images using the post "Gallery embed" control -- OK, it's not very intuitive, but it works, and I found it easier than posting first to, say, my shared Google Drive and fixing the URL to work properly in forum posts.
Re your non-working cruise control, anything else not working like it should on steering wheel controls ? The cruise control controls connect to the steering column control module J527, which, in turn, communicates with the ECU J623, where the cruise control functions are implemented. Note the Engine DTC about communicating with the Steering Column Control Module (hence, no signals for cruise control). Probably not a coincidence. --g
Drclaw
ME
@DrGERTol played with the VCDS a bit today and cleared up a bunch of codes. I have one left, probably related to my cruise control issues. No other issues with my steering wheel of MFSW buttons, everything else works as expected.
Code:
Monday,05,September,2022,14:48:12:39469
VCDS Version: 22.9.0.0 (x64)
Data version: 20220830 DS341.0
www.Ross-Tech.com
Scan: 01 03 05 08 09 15 16 17 19 25 2B 42 44 46 4F 52 56 62 72
VIN: 3VWML7AJXEM625063   Mileage: 113750km-70680miles
01-Engine -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
   Coding: 0050072
   VCID: 2F6DD2E9BE8761F5EA-807A
Readiness: 0 0 0 1 1
   Revision: 00H46001
   Coding: 114B600C492400FF880B06EA921C0042A1000022
   VCID: 7EF33FADE96D587D31-802A
   Coding: 030C0C
   ROD: EV_KESSYPQ35G_A02_VW31.rod
   VCID: 3467DD859FA1422D97-8060
   Revision: 00001002
   Coding: 0010001002
   VCID: 75E12081D45B1B2560-8020
   Revision: BG122001
   VCID: 3D71F8A1A4EB836568-8068
   Coding: 009795
   Coding: 00004E42
   VCID: 3C77F5A5B7F18A6D5F-8068
   Coding: 1082140000
   VCID: 01094451909327854C-8054
   Coding: 820000
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 86
                    Mileage: 113754 km
                    Date: 2022.09.05
                    Time: 02:46:05
   Coding: 271D01
   VCID: 3561E08194DB5B25A0-8060
   Coding: 352002
   VCID: 7BF536B9FA7F4D5516-802E
   Serial number:
   Coding: 000007
   VCID: 6ADB03FD8DE5C4DDFD-803E
   VCID: 306FD1956BB97E0DF3-8064
   Coding: 0004B5
   VCID: 5BB5563952BFAD5576-800E
   Slave Driver:
   Coding: 000490
   Revision: 00H22000
   VCID: 3979ECB170C3BF4544-806C
   Coding: 050B0500
   VCID: 6FED12E9BE0721F5AA-803A
   Coding: 0004B4
   VCID: 5CB7552557B1AA6D7F-8008
   Slave Passenger:
   Coding: 000490
   VCID: 4C97A565EF513AEDEF-8018
End-------------------------(Elapsed Time: 03:03)--------------------------
