Morning Backfire
DMAC
Philadelphia, PA
2009 Jetta TDI
Every once in a while (around every 2 weeks), I turn on my 09 Jetta TDI and it starts without any problems. About half a second after the engine starts, I hear what sounds like a backfire in the engine. It only does it when the engine is cold. This is my first diesel so I don't know if this is common. Is it bad? Should I take it to VW?
Lefty
Lazear,Colorado Population 60
Jetta, 2000,Green GLS
Are you letting the glow plugs to warm before starting? Not sure if this falls under the Warm up Hic-up or not.
tnteggroll
That reminds me, my glow plug light goes off within probably a second of turning the key on. Is that normal, or is it malfunctioning?
kcfoxie
Raleigh, NC
'12 6-spd JSW
The GP is only needed if the temp is below 40F. If it's above that a sub-2 second illumination is normal.
AndyBees
Southeast Kentucky
Yeah, them spark plugs are igniting the left-over "gasoline" just after a cold start! Well, some do talk about their "gas" milage! Heck, it could be a gasoline diesel!
Lefty
DMAC said:
My glow plug lights go out after maybe 1 second. The problem happens even when it's 80 deg. outside.
Well that is not normal. Before starting the car when it is cold out turn the key on for about 8 seconds and then start the car. Should fire up . Have a Scan done on your car so you might get an idea why the glow plug light is only coming on for 1 second.
NMRJock
Grand Rapids, MI
'09 Jetta DSG
It sounds normal to me. Our glowplug light in the '09 is only on for a flash when it is in the 40's or 50's. The glowplugs stay on considerably longer in the '00.
We don't get any sort of 'backfire' when we start it though. I'm not sure what that's about.
740GLE
NH
do a search for a warm up hicup or warm up shudder, it was noted that a few 09s had an issue when the car was warming up the loss of power for a rev then everything normal, people think that this is an exhaust valve shutting.
What might be happening is your valve might be acting up and slamming shut then poping open causeing what would sounds like a backfire.
I haven't looked into all the parts of the emissions system and this is just a wild guess.
But what you have doesn't sound GP related, as my GP light flashes for a second at 80 too, and the longest i've seen it on was about 4 seconds when it was 29 degrees last week.
Lefty
So even when it is Warm out the hicup happens?
Is the 1 second glow time even when the car is cold or when over 40 Degrees?
DMAC
Philadelphia, PA
2009 Jetta TDI
1. yes
2. The coldest it has been here since I got the car is 40 and it's in a garage so it's warmer than 40. It happens no matter what the temp.
Lefty
DMAC said:
1. yes
I don't know the answer you need. Someone will though.
On a side note: 40 Degrees is the lowest temp there so far? Wow I was in single digits this morning.
