More power from pumping brakes
TDI Power
Burnaby B.C. Canada
Jetta, 98, Red
Recently I noticed when standing at a red light and pump my brakes a few times, my car takes off much faster than if I didnt pump the brakes. It feels very peppy for 5 minutes or so, and the brake pedal is more sensitive too.
Anyone have any ideas what might be causing this?
Toronto_Vento
Richmond Hill, ON
01 Baltic Green Bora
When was the last time you had your brake fluid flushed? Sounds to me like you have a bit of low pressure. Pumping the brake pedal increases the presure of the hydraulic fluid in the system. That means your brakes will release quicker (hence your slightly faster takeoff) and your brakes will feel more sensitive. The clutch on these cars are somewhat hydraulic, and use the fluid from the brake system. Pumping your brakes also makes the clutch work a little better.
If you haven't done this in the past two years, get your brake fluid flushed! It isn't a difficult job if you have some tools. If you have had the brakes flushed according to schedule, check your brake lines. Could be losing pressure somewhere.
TDI Power
Burnaby B.C. Canada
Jetta, 98, Red
Changed my fluid about a year ago, but now that you mentioned the clutch, yes it feels better too after pumping the brakes, it also grabs higher. Sometimes the clutch will grab all the way at the bottom, then after pumping the brakes, it will grab higher.
Checked out all my lines and no leaks, could it be a bad master or slave cylinder, clutch or brake? Thanx
Peter Cheuk
Gasser :P
Daly City, Calif., USA
'06 Jetta GLI
Hmm, I think that pumping the brake pedal is working out your right foot so what you are experiencing is that your right foot has more strength to press the pedal and so it does it more hence the "increased power". In other words, I don't have a clue why your car is quicker when you pump the brakes.
TDI Power
Burnaby B.C. Canada
Jetta, 98, Red
Peter, LOL, nice try
. Its, weird, the brakes are fully released because when I stay at the slightest incline the car wants to roll the same way if I pump the brakes or not.
I wonder if it has anything to do with the brake booster, after pumping the brakes, maybe there is less load from the vaccum pump on the engine?
Peter Cheuk
Gasser :P
'06 Jetta GLI
I tried it the other day and it did not seem to make any difference in power on my car. I did notice that the throttle pedal felt lighter after pumping the brakes, though.
TDI Power
Burnaby B.C. Canada
Jetta, 98, Red
Thanks Peter, good to know its not normal. I'm also starting to notice after pumping the brakes, when I keep pressure on the brake pedal, the pedal slowly sinks about an inch. Will have to investigate more.
tdibeliever
Urbana, IL
None currently- just pieces
SOund to me like your Master cylinder is failing, or you have air in the system. I'd suspect it's a bad M/C first. The fluid is flowng by the worn piston seals causing the pedal to sink.
