blizzard60
So I've tried to search for some help on exactly how to get the "SKC" value from a cluster using VAG Tacho, but I can't seem to get the answer I need. In a lot of the posts I've read people call the 4 digit pin the "SKC", but they aren't the same thing (this is probably obvious to most people, but is seems like a pretty common thing to use PIN and SKC interchangeably which is very confusing!!!). This is where I think I'm having issues.
I can log into the cluster (1J5 920 846 C) with VAGTacho 1.7 no problem. If I choose the "get pin" option it returns a value right away (9637). I have tried to re-code some keys with this pin, but it doesn't work. I've tried using the "new keys" option in VAGTacho but it says wrong pin, then I have to re-login. I've also tried VCDS and I get disconnected from the cluster as soon as I try to log in with that pin. Under BOTH circumstances I get a "FAIL" on the right display of the cluster where the normal "trip" distance is.
I have tried a hole bunch of sequences with these digits (3796, 6973, 7369, etc!). When I use VCDS I always add a 0 before the pin. I can only use 4 digits in VAGTacho...
I have several EEPROM dumps, but I don't know if the 7 digit SKC is in there somewhere... This would be useful as I have a date and a workshop number for the last dealer that logged into the cluster.
Any thoughts? I'd really like to able to adapt some keys!!!
Thanks so much.
Thanks so much.
