MOGolf
- Joined
- Jun 27, 2001
- Location
- underneath something
- TDI
- 2001 Golf GLS TDI Reflex silver, rough road suspension and steel skid plate, 2004 Passat Variant, Candy White, rough road suspension and geared balanced shaft module, and much, much more. 2016 LR RR HSE TD6, 2019 Jaguar I-PACE
Thanks goes to Dan at Hillside Imports for obtaining the springs, IMPEX for the other bits and pieces, and Gearhead for lending a hand on the install.
As most of us are aware the VW steel skid plate adds weight to the car's nose. Combined with about 109K miles, and carrying a few things
to GTGs, the original springs were getting soft(er). Even though I have Bilstein HD struts and shocks, struts and shocks are not meant to support the vehicle, only to dampen the spring oscillations.
I decided it was time to get new springs. Preferring to remain close to factory fit of parts, I investigated VW's selection of springs. Cars built for North America don't get much in the way of choices. It's mushy, or "sport".
European cars have other choices.
The skid plate is part of a "rough road" package. This includes different springs, struts, shocks, a bearing spacer for the front struts, brake line protector and fuel line protector. I have the latter protectors installed (covered in another upgrades thread), so I decided to get the proper springs and spacers associated with the "heavy duty suspension" part of this package, keeping the Bilstein HDs instead of getting VW issue struts and shocks. They have about 56K miles on them and are in good working condition still.
Investigation of my car showed 'L10' as the spring code for my automatic equipped Mk IV Golf. 'L09' is the code typically found on manual transmission equivalents. This provided the weight range for the springs of 731-760KG as noted in VW information.
Since I added weight to the front of the car (skid plate) and carry a few things, as noted, I decided to up the weight range while changing the springs. That meant going through information about the "G10" code for the "rough road" package and finding the correct spring code for the weight range. I selected the L47 code for the 751-785KG range. There is only one more higher weight range (the L52 code springs rated 786-840KG) but I thought that might be getting a bit too stiff for an unloaded car situation.
Having made the selection I ordered the springs from Hillside Imports and for approx. $330 delivered I got 4 new springs to install. The other parts (bolts, nuts, bearings, spacers, bushings) I got from IMPEX.
Front spring p/n 1H9 411 105 F (4 white, 1 blue dots)
Rear spring p/n 1J0 511 115 G (3 silver, 1 green dots)
Gearhead came over to assist and we took a test drive with the original worn springs. We both agreed that nose dive was becoming prominent during cornering. We measured the ground-to-top-of-wheel-opening height at each wheel. 66.8cm (RF), 67cm (LF), 69.2cm (both rear) with front tires at 35psi and rears at 38psi (what I typically run unloaded).
Then we installed the rear springs and went for a test. Handling was, how shall I put it, not acceptable. The test was short and we returned for fitting the fronts. Then we took the same test course as the original drive and there was a very different car in my hands. Cornering was much better and could be achieved at higher speeds. Nose dive is practically nil even when coming to a straight stop. Ride is stiffer, but not unacceptable. Lowering the air pressures could soften the ride.
Vehicle height is notably different too. Front came up to 70.1cm on both sides and the rear to 70.9cm on both sides.
Gearhead measured the thickness of the coils for the springs.
Stock rear 10.8mm, HD 11.57mm
Stock front 12.25mm, HD 13.47mm
I'll let gearhead add his own opinions and observations about the ride difference.
Note: these are springs for the Golf. The proper selection for similar springs to equip a Jetta/Bora or NB must be done if you intend to upgrade one of those vehicles in a this manner.
I'll post again after they've been worn for awhile and I get a chance to load up the car for a true 'heavy hauler' test.
