josh8loop
- Joined
- Sep 15, 2009
- Location
- Vero Beach, Fl.
- TDI
- 2002 VW Jetta TDI Manual(performed 01M to 5-speed swap) - 183,000 miles and climbing!
For those that don't want to read through the many pages of this long Thread, here is the Cliff Notes version. Basically I found out that two thermostats can be purchased and parts mixed and matched to give a thermostat that will control at around 205 Deg F for the ALH engine instead of the stock 195. Jump to page 3 post 39 for the part numbers. Page number 4 post 59 shows some photos of the transformation. I have some assembly videos on the construction that can be seen here:
http://www.youtube.com/watch?v=AU8IAcGIYVo&list=UUd7-nt4jVRMYngwv-0WSMbw&index=8&feature=plcp
http://www.youtube.com/watch?v=x7hodv7Rsvg&feature=related
Remember this is all experimental, and Mod at your own risk. Also, it is not recommended that you fiddle with coolant temps if you have an automatic transmission. With that said, in 15K plus miles I have had no mechanical issues from doing this, and am noticing a 3-4 MPG bump from my previous worn out stock thermostat. I have however replaced most of my old coolant lines, hard coolant pipe seal, and other brittle plastic coolant fittings. At this point we have at least two others that are trying this modified thermostat, and feeding results occasionaly. One of our members also mentioned that a stock MkII thermostat rated for 92 Deg C(197.6 Deg F) will fit the ALH engine too-not quite as high as the "Hybrid" unit, but the mkII version is a drop in replacement. For the longer version on the development of the "Hybrid" version, please read on........ ......
Fellas,
I have recently come across information where people have modified their existing thermostats with parts from other thermostats to gain higher coolant temperatures. See here:
http://www.cadvision.com/blanchas/Ranger/Thermostat.html
Since our thermostats are of the double valve thermostat type it would be important to make sure the end product functioned exactly the same as the old one in terms of internal engine bypass flow control. Not saying that this would be the best idea on the block to help us achieve higher overall engine temperatures, or the most easy to construct, but sense we cannot purchase over the counter T-stats in the ranges desired we are forced to get creative.
Here is a Stant part number of a t-stat that is rated for 205 deg F:
14252(remember your in the non-cliff notes version. Skip to page 4 post 59 for some photos and the part number I ended up actually using to make the "Hybrid")
I hope to do as side-by-side comparison of this thermostat and a replacement for my TDI this evening and see what the potential for swapping the internal parts would be. If the parts look interchangeable, I hope to purchase one of each, and test the 205 degree one to see if it will actually open at 205 degrees. If it opens correctly, I could begin the swap process and testing the results in the car.
One final question I would want to get resolved before proceeding, is it safe for our cars to run at a sustained 205 deg F temperature?
Fellas,
