tditom
- Joined
- Sep 5, 2001
- Location
- Jackson, MI
- TDI
- formerly: 2001 Golf GL, '97 Passat (RIP) '98 NB, '05 B5 sedan
ruking- are you using Delvac1 or TDT?
One thing I have noticed about the CBEA engines: the oil STINKS bad when drained, and it is SUPER HOT. Unscientific of course, but without a doubt VERY different than any of the VE or PD VAG diesels, and the MB CR diesels we also commonly service. I mean when you crack the drain plug on a VAG CR engine on the lift, you can smell it 2 bays away. Smells like burnt butt hair and asphalt, and you can easily burn your hand if the engine was just running at operating temp.The VW 507.00 oils use very high quality base stocks, but the chemical limits required by DPF equipped engines really reduce the additive treat levels. Based on the analyses I've seen to date, I'd say 15,000 mile oil change intervals are achievable in the CBEA engines under ideal conditions. If you were able to safely run an API/CJ-4 oil in the new TDI's, I'd think that 20k-25k intervals would be achievable.
TS
While I do not MIX them, I use them interchangeably. Batches of Mobil One TDT gotten @ local (distant also) WalMarts. Delvac One purchased @ a local truck stop/oil distributor (Western States)ruking- are you using Delvac1 or TDT?
What do you make of this?One thing I have noticed about the CBEA engines: the oil STINKS bad when drained, and it is SUPER HOT. Unscientific of course, but without a doubt VERY different than any of the VE or PD VAG diesels, and the MB CR diesels we also commonly service. I mean when you crack the drain plug on a VAG CR engine on the lift, you can smell it 2 bays away. Smells like burnt butt hair and asphalt, and you can easily burn your hand if the engine was just running at operating temp.
I would be curious if any of this plays out in a UOA on these engines as being anything to worry about.
