GlowBugTDI
- Joined
- Jul 20, 2018
- Location
- Cambridge, MN
- TDI
- 2001 Beetle GLS TDI (BIODSL). 01 original Glow Bug TDI (sold)
i just don't know a whole lot when it comes to timing. and idk it it's retarded, or the injectors are failing...all you need is a 13mm short socket and ratchet, and a channellocks to adjust the timing
pull the timing cover, make note of where the three pump flange bolts are in their slots, loosen them (the pump shaft might jump forward or back at this point) then just set it a little bit clockwise of where it was and hold while tightening the 3 13's back up again
they might be 12mm heads if they've been replaced
if it is too far advanced it'll just set a totally ignorable trouble code, it'll set codes about 5 degrees before you even reach where it'll start nicest
if you manage to adjust it way too far you'll just have hard starting and bad fuel economy. You just about can't hurt these motors with the stock fuel injectors' output
the reason i haven't done injectors is i felt like if im gonna put money into injectors i might as well upgrade (like the euro ones), but ive read you might as well do a tune before that. but i can't spend the money for a malone stage2 tune, clutch and having injectors popped, so now i just wait and think about having a stage 2 car lol... until i bite the bullet and send them in for stock tips.
