SirSipsAbit
Hello gurus,
I am in process of doing a brake upgrade on my 2012 jetta premium TDi. It has the 6 SPD manual.
I have discovered that the rear rotors I received are 272mm and my stocks are 260mm. Looking on rock auto.com, it appears there are many 272mm rotor choices for 2012 but only a couple that are 260mm.
Anyway, do you know any detail on when the change in brakes took place, what size is most current? Is a simple caliper bracket swap all that is necessary if I want to run the 272mm?
Thanks!
Thanks!
