MWCAdmiral
I came to the same conclusion - air in the system. I was finally able to tackle this problem today and, after much reading on these forums and lots of reading in Bentley's manual, I was able to get it working. It was so nice to hear the purr of that engine running again after I managed to cause it problems by doing what I thought would be easy maintenance. When it's time to do it again, I don't know if I'll try it again.nutdriver said:I have not encountered this problem on the PD engine but suspect that you have air that has entered your fuel injector system. I think the final solution will be bleeding the system. You might try a boolean search using key words such as:
Hopefully one of the experts will help with more details specific to this engine.
- bleeding AND fuel AND system AND PD
