MKIV Skidplate or Belly Pan
WantingaTDI
Washington DC (moved from VT)
VW Golf 03 TDI
I am in Vermont and looking for a used (good condition) skid pate or belly pan for my MKIV Golf. Metal Panzer Plate or another brand or the stock belly plan in good condition. Let me know if you have one.
Mark
Skydvr
Western MA
2002 Jetta MkIV
I’ll have to check the condition later today when I get home, but I know I have one from my landlord’s Jetta wagon that I am prting out. I do not recall if that is the one off their Golf that smacked an island in the road and got flattened out a little bit, or if it was the one from the wagon.
You’ll need all the mounting hardware and brackets for it, but I’ll make sure to price it so that it is reasonable for you. I can give you the riv-nut tool and oil change window cover if you want it (I prefer pulling the plate to inspect the engine, so I have never installed it). I may be able to get the mounting hardware and riv-nuts from work, though I’m not sure if we would have those in metric. That would leave you with neededing the mounting posts for $80 plus another $35 for the hardware and riv-nuts if I can’t source them at work.
I’m off 91, a little south of Greenfield. I can meet you by the highway if it makes your trek easier. If the timing works out, I could likely help you mount it in the garage. The instal is simple and straight forward, but it is always easier with help.
