Farfromovin
Torque Addict
Alright, I know there have been a couple audio build threads as of late so that's a good thing. Get more info out there so people can get different ideas! Here's the ingredients list:
Kenwood KDC-X995- Simple yet feature packed single din unit with hands free calling and Pandora ready.
JL Audio HD600/4 150wrms x 4 bi-amped to my components in the front doors.
JL Audio HD750/1 750wrms x 1 sub amp.
JL Audio ZR650-CSi 6.75" component speakers with passive crossovers and aluminum dome tweeters.
JL Audio 10W6v2 10" single subwoofer.
JL Audio XD-PCS2-2B 2ga amp wire kit with a dual fused distro block that breaks it down to 4ga inputs for each amp.
Start off with pics of gear in the garage I was piling up just waiting for everything to come in:
Yeah, it looks like I'm a JL fanboi and I suppose I am. I hung out over at DIYmobileaudio.com for a while and they're all big advocates of mixing the speaker brands and sizes yourself instead of buying pre-made "speaker kits" like the door speakers I chose. I figured it's like any other upgrades, you can do it yourself and experiment to find the ultimate results 2 years later and after 3-4 rounds of upgrades, or you can just buy pre-made "packaged" kits which is what I chose. I've been a huge JL fan for the last 20 years and have had a few systems with bits of their equipment here and there. This time I chose to just match everything up and it turned out pretty well I think.
All started with the head unit. I chose the Kenwood due to the features and price I felt it offers a large bang for your buck. I installed this in place of the stock double din Monsoon. It has a USB port on the back which I plug into my iPhone dock pretty much all the time I'm in the car. Charges while doing voice guided nav with hands free calling simultaneously through the car's speakers. Pretty nice upgrade over OE... I don't have pics, but I got the PAC audio adapter that Crutchfield sells for the late model MKIV's (mine's a 03). It works fine, but I'm a little dissapointed as it seems like I spent $60 just for key in acc line when I could have tapped into that coming out of the ignition switch. In either case, it works well:
It was all going to stop there except I saw the JL HD line of amps while shopping for the head unit and just fell in love with their size. They're like a high school text book, maybe a smidge thicker but not much. So, I set about purchasing the rest of the equipment. Some is new grey market, some I purchased used from locals via Craigslist, etc... The only thing I paid retail for was the Kenwood and that's because I got it the week it was released and I couldn't find it anywhere but an authorized reseller. Overall, I spend considerably less than half of MSRP for all this stuff, it's the only way I could afford it
Next up is the door speaker install. I pulled the panels off and realized I had to drill out the riveted baskets. Got those removed and now had to pull the inner card to properly sound deaden the entire cavity. VW doors are nice BTW, as they're well sealed compared to other makes!
If you plan on going this route, don't let the doors intimidate you, they're not too bad. There is a good writeup on one of the passat forums (I'll edit a link in here later if I can) that tells you how to remove that inner metal panel.
Here's with some Dynamat Exreme applied to the skin and the metal panel:
Then did the backside of the door card itself:
That added significant stiffness and mass to both the card and the door. Opening and shutting is really quite a treat now. Feels much more luxury in my book.
