KrashDH
Alright I set upon this adventure thinking that there has GOT to be a way to get to those triple square bolts without removing half of the front end and side of the car.
It's annoying when your door starts to droop and can cause all sorts of alignment headaches, noises, wind, sealing/moisture issues. But, I've been neglecting it for a couple of years. Was time to bite the bullet with all the work I've put into the car lately.
Now, by no means was my door as bad as some of y'alls, but my OCD said to fix it. Here's a couple of before shots:
Top:
Bottom:
Mid Gap:
Bottom Gap:
So here's a run down of the tools you will need:
This is the basic setup of tools you will need to get to the bolts:
First thing that I did was remove the interior kick panel. There is a triple square back there that you need to get to on the bottom kind of behind the hood latch.
There are a few write ups on removing that so I won't go into detail, but it's easy. You can wedge a flathead screwdriver on the back side of the handle where there is a plastic "keeper" cap. Pop this cap out and the handle slides off. Then the trim can just be removed, it snaps in place. I'm sure I broke a couple tabs removing it. Oh well.
Next thing I did was tackle the triple square bolt on the top of the door. With your 7/16 box end (ratcheting side) you can put your bit into it. There's a small shoulder on the bit that keeps it from sliding out while you're trying to get it in place. Go UNDER the door hinge to get to it:
I was lucky and with some brute strength it broke free no issues. I wore a glove in case something went flying and let go to protect my hand.
Continued next post...
Top:
Bottom:
Mid Gap:
Bottom Gap:
- 3/8" ratchet
- 3/8"-1/4" reducer
- 11mm socket (1/4" drive, short as you can find)
- 1/4" swivel u-joint
- 1/4" extension, about 4". i chose a wobble extension but you could probably get by with a standard extension
- 7/16 open end wrench, with ratcheting end (if possible for ease)
- Carbyne Super Short Triple Square bits (M8 for this job):
