FlexYJeeper
Ok, so with a test light or volt meter in hand, unplug the gp harness. Use the battery as ground. Stick the positive probe inside one of the gp connectors, doesn't matter which one. Have a helper turn the key to where the dash lights come on. You should briefly see 12v. If you have a volt meter, set to it to ohms and check the top of each gp to the block. Should see about 1 ohm. Should all be very close.
If you have 12v on any plug, then relay is good. Power all comes from the same place. And if one gp is bad, and you have 12v there, it would trigger a MIL. So I suspect you won't find 12v at the GP harness. Or I should say if there is a problem in the gp circuit, I would be surprised if you did find 12v there.
awesome, im waiting on a friend right now to help me out with it. so if there is no power the problem would be the gp relay?
