CodyR
Hello All,
I have got my 2nd coolant leak in the last month and I believe its the thermostat housing but not to sure. The last first coolant leak was from the water outlet on the driver side of the motor. The lip that the o-ring set on disintegrated. Since the thermostat housing is plastic as well, I'm assuming its what's leaking now. Has anyone else seen this problem before or seen the easiest was to get to the housing? From me initially taking it apart it looks like a major pain. Thank you in advance for the help.
