cpinde
- Joined
- Sep 24, 2012
- Location
- Slower Lower Delaware
- TDI
- 05 VW Passat, 04 Jetta, 06 BRM Jetta, sold 15 Golf current
I was driving and the car just died on me. Coast to a parking lot and it just cranks. I pulled an autoscan and there are no engine DTC's. When it sits for a day or two it'll start and run for about a second then die. I've logged different parameters while attempting to start. I don't see anything that's wrong. It's driving me crazy. I also haven't been able to work on it much between my kids and the weather. What is killing me is not having any codes AND it is starting then dying after it sits for a while. "Couldn't" have been bad fuel because I put 12 gallons in about 220 miles ago. Pulled the fuel filter and clean with no metal. I pulled the metering valve and it's clean, no metal. In VCDS I run the in-tank fuel pump with no issues. I'd assume if it was either of the fuel pumps I'd have some kind of code. ANY help is greatly appreciated!!
Code:
Tuesday,03,May,2022,16:38:35:63931
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 22.3.1.4 (x64) HEX-NET2 CB: 0.4615.4
Data version: 20220407 DS337.0
www.Ross-Tech.com
VIN: 3VW2A7AUXFM064002 License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 15 16 17 19 2B 42 44 52 5F 75
VIN: 3VW2A7AUXFM064002 Mileage: 330882km-205600miles
01-Engine -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
75-Telematics -- Status: OK 0000
Address 01: Engine (J623-CRUA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 997 022 N HW: 04L 907 309
Component: R4 2.0l TDI X23 9459
Revision: 85X23--- CVN: B5ADD45238D3FF82B866C2AD
Coding: 011D0012032410081000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_ECM20TDI01104L997022N 004002
ROD: EV_ECM20TDI01104L997022N.rod
VCID: 3B285F5373EA3B63DAD-806E
VINID: 0E69C2447465A1674018400008C2EA963C
No fault code found.
Readiness: 0 0 0 1 1
Address 02: Auto Trans (J743) Labels: 0D9-927-770.clb
Part No SW: 0D9 300 041 N HW: 02E 927 770 AQ
Component: DQ250-6F MQB H53 4512
Revision: 03253104 Serial number: TFK01411250892 CVN: 0000EF4F
Coding: 0014
Shop #: WSC 00066 790 00221
ASAM Dataset: EV_TCMDQ250021 001001
ROD: EV_TCMDQ250021.rod
VCID: 23188733EB5A63A3F2D-8076
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-ESP-V1.clb
Part No SW: 3Q0 907 379 P HW: 3Q0 907 379 C
Component: ESC H32 0385
Revision: 00000000 Serial number: 53184000001785
Coding: 01FA6AA1242609700077020081C52580562490004081A4B200630050C002
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_Brake1UDSContiMK100ESP 034033
ROD: EV_Brake1UDSContiMK100ESP_034_VW37.rod
VCID: 47C033A33F226F834E5-8012
Address 05: Acc/Start Auth. (J518) Labels:| 5Q0-959-435.clb
Part No SW: 5Q0 959 435 A HW: 5Q0 959 435
Component: VWKESSYMQB 021 0604
Revision: 00021000 Serial number: 0350889795
Coding: 030C0C
ASAM Dataset: EV_KessyHellaMQBAB 002011
ROD: EV_KessyHellaMQBAB_002.rod
VCID: 3A265A577CD0026BC1B-806E
Address 08: Auto HVAC (J255) Labels:| 5G0-907-044.clb
Part No SW: 5GM 907 044 A HW: 5GM 907 044 A
Component: Climatronic H03 1001
Revision: 00001K01
Coding: 00020114200100000005000012111400
ASAM Dataset: EV_ACClimaBHBVW37X 003018
ROD: EV_ACClimaBHBVW37X_003_VW37.rod
VCID: 42D622B714004AAB99B-8016
Fresh air blower control module (front):
A/C pressure/coolant temperature sensor:
Air quality sensor:
1 Fault Found:
328197 - Motor for Right Temperature Flap
B108D 54 [009] - Missing Calibration / Basic Setting
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 177
Mileage: 330882 km
Date: 2022.05.03
Time: 16:20:08
Voltage terminal 30: 12.7 V
Outside temperature: 14.5 °C
Inside temperature: 26.9 °C
Right temperature flap: actual value: 215
Right temperature flap: actual value: 99.0 %
Temperature door right - Specified value: 188
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 087 R HW: 5Q0 937 087 R
Component: BCM PQ37BOSCH 028 0145
Revision: -------- Serial number: 86582711140459
Coding: 00111846404182E969E44000001407001800000000000000000000000000
Shop #: WSC 00066 790 00224
ASAM Dataset: EV_BodyContrModul1UDSBosc 014004
ROD: EV_BCMBOSCH_014.rod
VCID: 4AC60A972C3092EB51B-801E
Wiper motor control module:
Subsystem 1 - Part No SW: 5GM 955 119 HW: 5GM 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 141129 043 0581
Serial number: 150106194550
Coding: 0E4DDD
Rain/Light Recognition Sensor:
Subsystem 2 - Part No SW: 5Q0 955 547 A HW: 5Q0 955 547 A Labels: 5Q0-955-547.CLB
Component: RLHS 037 0059
Serial number: S5Y14M11D24H22M55S32
Coding: 00A8DD
Sunroof control module:
Subsystem 3 - Part No SW: 8V3 959 591 A HW: 8V3 959 591 A
Component: J245 PS73.404 H02 0003
Serial number: 0000FST0000CHG900000
Coding: 181801
Humidity sensor: interior:
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 5Q0 959 655 T HW: 5Q0 959 655 T
Component: AirbagVW20 009 0825
Serial number: 003MHM01HGNZ
Coding: 8CCCFC00000000005000001AC24800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002138
ROD: EV_AirbaVW20SMEVW37X_VW37.rod
VCID: 51F41DFBC166A133101-8004
Seat occupied recognition passenger side:
Subsystem 1 - Part No SW: 4M0 959 339 B HW: 4M0 959 339 B
Component: BF-Gewichtss. H10 0021
Serial number: IBH0000J1400022VVG0N
Coding: 303137
Crash sensor for side airbag: driver side:
Subsystem 2 - Part No SW: ----------- HW: 480 001 811 14
Component: SideSensor_Df 001 0887
Serial number: 35700000000409AC811H
Coding: 2D2D2D
Front Passenger's Side Airbag Crash Sensor:
Subsystem 3 - Part No SW: ----------- HW: 480 001 911 14
Component: SideSensor_Pf 001 0887
Serial number: 358000000001017D2210
Coding: 2D2D2D
Rear Side Airbag Crash Sensor (on driver's side):
Subsystem 4 - Part No SW: ----------- HW: 480 402 310 14
Component: SideSensor_Dr 001 6149
Serial number: 3510002AF1811BA4B120
Coding: 2D2D2D
Passenger side rear thorax airbag crash sensor:
Subsystem 5 - Part No SW: ----------- HW: 480 402 310 14
Component: SideSensor_Pr 001 6149
Serial number: 3520002B31860BA140AY
Coding: 2D2D2D
Crash sensor for front airbag: driver side:
Subsystem 6 - Part No SW: ----------- HW: 480 402 909 14
Component: FrontSensor_D 001 6149
Serial number: 3550002A9175A922334.
Coding: 2D2D2D
Crash sensor for front airbag: front passenger side:
Subsystem 7 - Part No SW: ----------- HW: 480 402 909 14
Component: FrontSensor_P 001 6149
Serial number: 3560002AF175A90180EA
Coding: 2D2D2D
Address 16: Steering wheel (J524) Labels:| 5Q0-953-549.clb
Part No SW: 5Q0 953 521 AT HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0175
Revision: FF032032 Serial number: 20141120500189
Coding: 0410
ASAM Dataset: EV_SMLSVALEOMQB 001015
ROD: EV_SMLSVALEOMQB.rod
VCID: 045AE4AF4E94849BEB7-8050
Address 17: Instruments
Cannot be reached
Address 19: CAN Gateway (J533) Labels:| 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 AB HW: 5Q0 907 530 L
Component: GW MQB Mid 211 2203
Revision: -------- Serial number: 20111410000229
Coding: 0101000800087300EF0002081C0F00000001050000000000000000000000
Shop #: WSC 00066 790 07027
GVL: 01503C0000000600400C00008000C80000000000000000000000000000000000
ASAM Dataset: EV_GatewConti 011020
ROD: EV_GatewConti_011.rod
VCID: 71B4BD7B61268133301-8024
Generator:
Multifunction steering wheel control module:
Subsystem 2 - Part No SW: 5G0 959 442 P HW: 5G0 959 442 P Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H16 0101
Serial number: 29140002640620114482
Coding: 29FFFF
Address 2B: Steer. Col. Lock (J764) Labels:* 5Q0-905-861.clb
Part No SW: 5Q0 905 861 A HW: 5Q0 905 861 A
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 14000354376001
Coding: 5D00000000000000
ASAM Dataset: EV_ELVMarquMQB 004111
ROD: EV_ELVMarquMQB.rod
VCID: 343A746F5EB4F41B1B7-8060
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q0 959 593 B HW: 5Q0 959 593 B
Component: TSG FS 020 0025
Serial number: 111214060506SR
Coding: 003A13200000040000000000
ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT.rod
VCID: 40D228BF1A0C58BB8FF-8014
Rear Driver Side Door Control Module:
Subsystem 1 - Part No SW: 5Q4 959 811 D HW: 5Q4 959 811 D Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG DRV 007 0002
Serial number: 00000000000000331496
Coding: 011000
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 5Q0 909 144 R HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 125 1061
Coding: 0102
ASAM Dataset: EV_SteerAssisMQB 012140
ROD: EV_SteerAssisMQB_012_VW37.rod
VCID: 43D827B30B1A43A392D-8016
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q0 959 592 B HW: 5Q0 959 592 B
Component: TSG BFS 020 0025
Serial number: 111214060504UG
ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT.rod
VCID: 3FD02B4367F22743F65-806A
Rear Passenger Door Control Module:
Subsystem 1 - Part No SW: 5Q4 959 812 D HW: 5Q4 959 812 D Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG PSG 007 0002
Serial number: 00000000000000362484
Coding: 091000
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD1.clb
Part No SW: 5G0 035 876 HW: 5G0 035 876
Component: MU-S-NS-US 014 0645
Serial number: V7B02711142950
Coding: 027300020000000021220002001800001F0100340100010546
ASAM Dataset: EV_MUStd4CPASE 002040
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 6984D51B49F679F3781-803C
Display and control head 1 for information electronics:
Subsystem 1 - Part No SW: 5G0 919 605 K HW: 5G0 919 605 K
Component: ABT_Std_Nav H60 0030
Serial number: VWZ8Z9PS600D9E
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5QE 035 285 A HW: 5QE 035 285 A
Component: OCULowMQBUS 007 0564
Coding: 02730002C2823A017F1E06000000
Shop #: WSC 00066 790 00122
ASAM Dataset: EV_OCULowMQB 001003
ROD: EV_OCULowMQB.rod
End----------(Elapsed Time: 01:38, VBatt start/end: 12.6V/13.1V)-----------
