turbobrick240
- Joined
- Nov 18, 2014
- Location
- maine
- TDI
- 2011 vw golf tdi(gone to greener pastures), 2001 ford f250 powerstroke
Sweet, nothing a good tune shouldn't fix. Hope you can share some dyno results when you get a chance.
I think they dyno operator where I take it is getting tired of seeing meSweet, nothing a good tune shouldn't fix. Hope you can share some dyno results when you get a chance.
Just the first tune update made a night and day difference! Car feels awesome, and tuning is still not finished so I'm pleasantly surprised at this point. Had my worst tank for fuel economy since before I had stock exhaust still in place...44.5mpg for a tank of almost exclusively datalogging haha!I'm sure a good 2260 specific tune will make a big improvement. Though the 1752vrk probably did spoil you somewhat as far as transient response and spool goes. All that top end should more than make up for a few extra downshifts.
they have an o-ring in the turbine housing? I've seen the piston ring style seals in the later two-piece VNT housings but never an o-ring on the turbine sideMissing O ring seal maybe!
I guess O-ring is not proper term. There is a large gasket on turbine side that keep the leaks from happening. I guess turbine gasket is more appropriate term.they have an o-ring in the turbine housing? I've seen the piston ring style seals in the later two-piece VNT housings but never an o-ring on the turbine side
Same on EA288, I get 2bar by 2600-2700rpmThe 2260vklr should make easy 2 bar @2600-2700rpm if tuned correctly (at least on the old CR, dont know this new one).
For the leak maybe the oring is badly pressed inside or deformed and doesnt seal. That leak is not good.
Go into vcds and see voltages for the actuator at full open and closed.
Thanks! It'll be coming off soon unfortunately. Thinking the leak is only upon cold startupIts a v-profile sheet metal ring gasket.
I'd assume I'm similar with that same setup. Injectors next?So I got mine dyno’d recently after dealing with a year long transmission nightmare. Can’t find the dyno sheet on my phone but it make 209hp and 370 ft/lbs.with a gtb2260 and cp3
Stock injectors. I kept destroying the 1st and 2nd synchrosI'd assume I'm similar with that same setup. Injectors next?
What was wrong with your transmission?
Didn’t read that totally yes. I do plan on doing the injectors next when I have the money but that’s gonna be a little bit before I can do that.I'd assume I'm similar with that same setup. Injectors next?
