xjay1337
Interesting ;-)
Maybe you can be the test goat for the Mk7 engine like I have been for the Mk6 lol
Of course, everyone's dyno is accurate. that's what everyone saysI've been putting down around 132-138HP/230-240lb-ft stock with these cars on the dynapack, and around 172-178/285-302 tuned.
That includes competitor tunes, and our dyno is accurate.
andExactly. A customer with a 90hp ALH TDI and VNT-20 turbo went on a Dyno Dynamics that reported 260whp (3 clean pulls on it) and then a Mustang Dyno 20 minutes away that reported 183whp (3 clean pulls).
None of the dynos are accurate and most people don't realize this. It's pointless to argue which dyno is more accurate - Mustang, Dyno Dynamics, Dynojet, Dynapack, Superflow, etc. These are all $50k-140k machines and not considered top of the line. Even if you use a top of the line dyno, you still run into issues like load, gearing, tires, suspension, wheel alignment, dyno fan, ambient temperature, etc. all of which affect output.
For example with a Stage 2 CR140, a dyno operater can skew results from 155whp to 185whp by simply changing the software configuration.
A few more things (sorry for being long-winded, but I'm pretty passionate about dynos):
1. This is a good image that demonstrates the difference between accurate and precise:
None of the dynos are accurate, deal with it.
A precise/repeatable dyno is what you want. If you bring a car back to the same dyno 1 year later, you don't want to worry about numbers being skewed too much. Over time, a change in wheel alignment will actually change horsepower and torque readings. Hub dynos like Dynapack take tires, alignment, and suspension out of the equation and it has a reputation for being precise. It's one reason why I bought that type of dyno.
2. The same car should go on the same dyno to measure gains. Getting stock runs in before tuning is critically important. Doing at least 3 pulls on the dyno to ensure consistency is also critically important. If the car hops onto a different dyno or if you compare against another car with different dynos, then it's worthless.
3. You can't compare gains between two cars by horsepower and torque differences either, especially between 2 different dynos. Gains are more accurately measured with %. Here's a real-world CR140 Stage 2 dyno in Colorado at over 4,500 feet:
126whp stock -> 154whp tuned = 28whp gain (UNCORRECTED)
150whp stock -> 183.33whp tuned = 33.33whp gain (SAE CORRECTED)
That's just 1 dyno chart of the same car and same dyno run. The only change here is the correction. However, see this:
126whp stock -> 154whp tuned = 22% gain (UNCORRECTED)
150whp stock -> 183.33whp tuned = 22% gain (SAE CORRECTED)
The 22% gain from stock to tuned exactly the same.
So if you want to compare your car's gainst against another car on a different dyno, then using % is probably a little more accurate in some cases. Not really because there still are more variables. Also no one likes to publish their gains using % figures because that's just boring. It's cooler to say "200whp," "300whp," etc.
tl;dr Stick with one dyno to see your stock>tuned gains, preferably with high load and no correction, and don't compare against different dynos. If you want to compare two similar cars on the same dyno back-to-back in the same day (same ambient temps. etc.), just to see which car makes more power, then that usually works too.
Nice. I'm about to get dyno' d at a local diesel shop with a mustang dyno. They call the mustang dynos "the heartbreaker", so I don't expect bragging rights. Should be a good baseline though.Got three runs in today on a Dynapack. 82° w/ 42% humidity. HP seems a touch low, but this looks to be a good baseline. All runs were pretty consistent.![]()
Sent from my Pixel using Tapatalk
That pic makes me angry/sad that VOA doesn't see fit to bring the Scirocco here. That is a beautiful car!I'm not sure, but that would be good if it is.Haven't seen a Mk7 head.
I'd love to put an LSD but our exchange rate is awful and has pushed the price up of them.
Plus I get major wheelhop in 2nd and 3rd, and I worry with a diff it will make it worse.
Water injection would be good in your case to keep EGT down, doesn't need mapping in as such , decent map will have EGT protection written in![]()
The stock air/water intercooler works fantastic. Did a few logs yesterday at 88° temps and the max post charge air cooler temps were 122°. The thought of water/meth injection here would be pretty nice. I even have a 4gal tank, pump, lines, and wiring already installed and not being used . Would be slick to use the DEF components with just a proper injector mounted. But, I think it might be best to wait and see what the final outcome is with the new turbo!I wonder if a fmic would help lower egt' s. Do you have any turbos in mind for an upgrade? I've been hearing great things about the gtd1752.
Nice. The a2w intercooler certainly looks like it would be pretty effective based on its size. I think water/meth inj. would be very cool (in a couple of ways)too. Can't think of a better use for the existing tank and wiring.The stock air/water intercooler works fantastic. Did a few logs yesterday at 88° temps and the max post charge air cooler temps were 122°. The thought of water/meth injection here would be pretty nice. I even have a 4gal tank, pump, lines, and wiring already installed and not being used ?. Would be slick to use the DEF components with just a proper injector mounted. But, I think it might be best to wait and see what the final outcome is with the new turbo!
The turbo is going to be a GTD2060 (likely hybrid), Ryan hasn't supplied me with any specifics and I'll respect that since the kit still needs to be test fit. You're right though, I've heard some good numbers out of those 1752s as well.
my alh is at 600F or so at 80 mph, flat ground, preturbo400C is pretty low in effect, probably the wrong sensor.
It's a Buzzken downpipe with one resonator though probably not a big difference. I have been contemplating a second resonator, but wanted to wait till the new turbo was on before making the final decision. I'll see about making a clip soon.Interesting, ive seen 250F oil temps indicated by the MFD in 98f doing about 75 up hill.
Have any sound clips to share with the rawtek setup on?
It's a bit different because of the new platform and it's slight differences. There are a couple of these that I know of running a GTB2260, and I'm sure they ran into some of the same things.Sounds pretty complicated compared to normal plug and play setups (gtb2260vk and vklr options). Curious how it turns in the end.
With just the Stage 2 eco tune in place, it feels pretty robust! Max EGT was 815C at ~4800rpm. Getting limp mode for "stuck actuator" but only when I take it to 5k rpm...all other driving feels fantastic. Maybe a touch more laggy under 1500rpm than the smaller stock turbo which isn't bad at all, there's plenty of power from 1600rpm and up though. This will obviously all change once the tune is dialed in.Nice! Can't wait to see what the gtd1752 is capable of. From what I've heard, it sounds like a pretty ideal upgrade for a daily driver.
