MK7 cv axle torque specs
bmwM5power
Rochester NY
15 GSW TDI S 6MT / 02 JETTA TDI GLS 5MT 15 GOLF TDI 6MT
Does this seem correct for auto tran axles?
outer axle bolt WHT005437 ( M16x1.5x70) 70Nm (~52 ft/lb) +90 deg TTY
inner cv to transmission 6x N90991002 ( M10x23mm) 70Nm ( 52 ft/lb)
ticaf
US Mid-Atlantic
Stock 2015 Golf SW S Manual TDI
I have 200Nm +180 deg for WHT005437, clean thread with tap
and 70Nm for N90991002
Nuje
Island near Vancouver
Be sure to have some heavy-duty tools at your disposal to get to that 200Nm+180° - that's a lot of torque. It's important to get to that torque, too, because if you come up short, you're most likely going to get some vibration issues at speed, leading to replacing the bearing and probably a set of tires.
I had to jump up and down on my ¾" socket drive to get that M18 XZN all the way around, after the ½" breaker bar blew apart.
740GLE
NH
70nm +90 sounds way easier :D lol
