mchapek
So I FINALLY did a 95% (my best guess) coolant flush on my 2015 Golf TDI Sportwagon (the dealership wanted $250 to do it). I've searched and searched both here and the internet, and have found virtually ZERO procedures that actually do a TRUE FLUSH (and I mean a FULL-ON FLUSH like I used to do with my older radiator cars with the old Prestone kit where you hooked up a garden hose to the system while it ran and in just a few minutes you had a complete flush...you know, a 100% flush of all the old fluid and sediment that is in the system).
All of the videos that I did find basically just say to pop the two lower hoses (the big one on the drivers side of the radiator and the smaller one on the passenger side)...both have the little clip you slide up and it locks into the 'unlocked' position, then you jiggle/wiggle/curse until the plastic fitting until it finally pops off, (sometimes taking skin off your knuckles when it happens suddenly) and drain both of those into my radiator fluid drain pan. Those two hoses (which is all you can readily get to) net you about 3/4 of a gallon of fluid. The entire system (according to the VW fluid capacity chart) is 8 liters (2.1 gallons). My car has 63,125 miles on it and as far as I know the fluid was stock (I bought the car 2 years ago, it was one of the buy-back models, had 38,000 on it). The fluid was pretty much orange (ie, a very dirty pink). I'd drain what I could, then using my air-compressor and the radiator vacuum system kit I bought on ebay for around $35 (WELL WORTH IT, works GREAT!) I'd pull a vac on the cooling system (after reconnecting the hoses obviously). It would easily suck back 3/4 gallon (of distilled water, as I'm just flushing the system many times to get MOST of the old fluid out). I'd put the cap back on, drive it a few minutes and re-drain the 2 hoses again, each time getting lighter and lighter colored water. I did that FIVE TIMES, and the last one the water was very diluted, and then I sucked back in 3/4 gallon of undiluted G13 VW coolant. I hope to top it off a few times with more undiluted fluid to get the entire gallon into the system (thus getting the recommended 40% mix of G13 to distilled water).
What I would like to know is just HOW does the dealer service department do a flush? They can't possible do what I did (took the better part of a day and was a huge pain in the you know what). I have Vag-com, and have seen comments like 'don't drain any more than those 2 hoses without Vag-com)...but can't find any procedure using Vag-com to open up places inside the engine that I can't get to when draining to get it all (or even most) out at one time. How is it possible that the Mk7's have been out for YEARS now but NOBODY has posted a good video/procedure on how to do a true flush/fill? My old MkIV has detailed procedures on everything you could possibly want to do...and there is squat out there on the Mk7's. I'd sure love to know how the dealership does this (just what does the $250 at the dealership pay for besides one gallon of G13 coolant)? Certainly they have VagCom, so just what is their procedure? Anybody? How can I get more than 3/4 gallon of fluid out? (ie, how can I get the entire gallon of undiluted fluid IN)?
