RIP TDI
- Joined
- Feb 16, 2000
- Location
- Santa Barbara, CA
- TDI
- '15 GSW SE 6MT...... '01 Golf GLS 5MT.... '96 Passat Variant....
Thanks for the update.
yes chrome peeled off razor sharp just peeled it off edgeOk, I know this sounds retarted but has anyone else sliced their hand or finger on the trim around the automatic shifter once you open the door forward of it? That silver piece is extremely sharp, i've sliced my dang thumb on it twice…. Am I the only one? Thanks.
Was the 2013 you drove fixed? If not it would probably feel more powerful on tip-in.
Are both DSGs? Fixed vs. unfixed DSG programming would also make a difference. And even fixed CJAA (engine code) and CRUA with DSG re-programming would feel different.
My point is that your perception of which car felt slower may be misleading. There may be nothing wrong with your car.
How much this rocketChip2 is gonna cost? Does it increase fuel consumption?I had driven my GSW (manual) back in 2015 pre stop sale. When I took delivery on the car I was disappointed by the lack of response to the accelerator when starting out. Compared to my older TDIs (all tuned) it felt very sluggish. Rocketchip Stage 2 fixed that.
Not sure what he charges these days, probably around $450. And I tuned my car at 800 miles so I didn't have a before and after for FE. My lifetime FE average is 42.4 MPG. I don't really drive for economy.How much this rocketChip2 is gonna cost? Does it increase fuel consumption?
thank you,Look into changing the throttle response coding before you spend money on a tune. There are threads about it, well worth the coding time.
It takes that spongy/sluggish throttle response and makes it linear which is more like the Gen1 you are comparing it against.
Did my own 40k DSG Service Last weekend. Fall of 2018 just as predicted earlier in this thread... lol
Had to remove the Air box, Battery and Tray to get to the DSG Filter housing. Tray has one bolt that hides under the drivers headlight adjuster and a red power wire so I had to use a torx bit to unscrew that one bolt as none of my sockets would fit in the small area I had to reach it in.
otherwise, service was as expected, drain out fluid that still looked good and not much darker than the new stuff I was putting in, take forever to refill the 5L from the top through the center of the filter housing, start car after finishing all the other filters, drain out excess fluid from the bottom, and button it all up.
good times.
Pre-warming is more key than that funnel and smaller hose, hotter the better for that fluid >100F is ideal.Timely! I'm planning to do mine this Saturday. Thanks for heads up on the hidden bolt. I may do a trial run on the battery tray on Friday before I take it to the lift at the local military base. I hate hogging a lift while fumbling.
I got the starter kit from ID Parts with the funnel and sized fitting to bottom fill. Hoping that saves a little time. I plan to pre-warm the oil jug.
I, and at least a few other people, have had leaks at the "fixed" (replaced) DEF injector after the phase2 fix; I'd suggest checking up on it in the first couple thousand miles after you get the fix.Scheduled my Phase 2 fix for 12/17/18. Should be getting both 2a & 2b since I will be over 45k miles by then.
Is there a what to expect/ask for thread for the Phase 2 fix I should be reading so I don't set my expectations too high..
I just did mine for the first time since owning the car (@113k mi). Not a bid job, but would be so much easier if the filter was accessible WITHOUT removing the battery/tray...Did my own 40k DSG Service Last weekend. Fall of 2018 just as predicted earlier in this thread... lol
good times.
Not the voice coil, it's the suspension. Just like on car at -20.Cool job!! One of my biggest hobbies is sound reproduction and pro PA systems and home audio systems. Temperatures will definitely affect the workings of a speaker and how they sound. The speakers in my 03 are the same way, after listening to a bit of music at a low to normal volume the voice coils heat up and they sound normal again. Im looking into buying a MK7 Golf TDI within the next few months and was cruising this post for problems. Im glad none sound to major yet. My only complaint is not being able to actually build cars to order anymore. Slightly upsetting. Carry on!
I too have a rattle and am yet to locate it. Sounds like it's from the center console. I hear it both at idle and highway speeds. I had the car in the air doing DSG and oil and took a look around at the heat shield, but I couldn't locate anything. That is the most annoying thing to me (other than oil filter location) in my one year of ownership.I just tried the above recommendation as I have a similar rattle. My solenoid bracket was tight already, but snugged it a touch more. My rattle sounds like it's coming from the dash though, but doesn't happen enough for me to really dig into. My armrest rattle on the other hand, that one I may try to fix.
Yes if anyone offered a filter relocation kit id be on board for that.I too have a rattle and am yet to locate it. Sounds like it's from the center console. I hear it both at idle and highway speeds. I had the car in the air doing DSG and oil and took a look around at the heat shield, but I couldn't locate anything. That is the most annoying thing to me (other than oil filter location) in my one year of ownership.
