KrashDH
Edit: Feel free to skip to Post #7 if you want to just see the final outcome. I was trying to make this a clean install without cutting, splicing or anything like that. I thought I was getting close into finding the wire terminals that I needed for the MK4 clockspring plug, but in the end, searched high and low, through all the threads here and on Vortex, and even with the "official" terminal threads, the clockspring terminals are still a mystery.
I wanted to avoid soldering because my soldering skills would have left too much solder on the joint, and I didn't want to increase any resistances on a critical airbag circuit, since they are sensitive.
Hey guys;
Trying to potentially source some VW terminals that are used on the clockspring plug for the MK4.
Here's the images of the 2x plugs I'm swapping. MK6 being the larger and MK4 being the 5 pin (flat). I'm doing a swap and trying to keep it as OEM as possible. I purchased from Canada what I thought was going to be plug n play harness, but unfortunately it's not for the 3-spoke Mk4.5 airbag, it's for the curved sides Mk4.5 airbag. I was willing to pay the money for what I thought would be a plug n play harness but unfortunately I'm either going to have to modify that one or find the correct terminals.
So I'm wondering if anyone knows what terminals are used in that MK4, 5 pin connector.
Thanks in advance!
Hey guys;
Thanks in advance!
