Tankbuster
Replaced my glow plug relay with a new 530 relay and still have the starting problem when the engine is warm mostly. Noticed if the glow plug on the dash lights up it will start, but if no light no start.
Where's the location for relay? I may have this same issue.its possible glow plug relay issue. other friend of mine with MK6 Jetta has exact same issue, replaced the relay, she fires up quickly.
last weekend, I did a swap of glow plug relay from 2015 Passat to 2013 Jetta TDI, noticed she cranks and fires up normally then swap back to the old one, she does it again randomly. have to keep testing it to see if the pattern is the same then replace it. I'm watching her car for a while.
Had a car scan done on my TDI.
This code come up 01314 Engine Control Module No Signal/No Communication-Intermittent
Thanks for the good information, will start looking for a loose wire or bad ground wire.01314 - Ross-Tech Wiki
wiki.ross-tech.com
Glad you got your TDI sorted outGood news! Took my TDI Jetta to a independent diesel repair shop and the guy checked all he could and was pretty sure it was
the ECM so I sent it off to a ECM repair place called ModuleExperts in jacksonville, Fl. It took them several weeks because my old ECM was for some reason pretty fried, but Chris at ModuleExperts explained they needed to build me a new one because the old one was shot and VW makes it as hard as possible for them.. They did a great job and now my Jetta starts the first crank every time now. Highly recommend them.
Sounds like a very fishy fix...built a new ecm?? Hogwash!Good news! Took my TDI Jetta to a independent diesel repair shop and the guy checked all he could and was pretty sure it was
