Mk6 Jetta tdi dash lights are on
abnersaleniuuc
Vancouver, WA
2014 Volkswagen Jetta (mk6)
Hey I was wondering if any of your guys know what is up, I have a 2014 Volkswagen Jetta tdi sedan and when you turn on the car the traction control light, low tire pressure, ABS, and the airbag light turn on, on the dash board, I’ve plugged in a OBD2 scanner and no codes popped up at all. One thing that I think it might be is the wiring or something around those lines. If any of you guys know that would be really helpful.
Bob S.
Central MD.
A B4V, some ALHs & BRMs
Try cleaning the grounds in the engine compartment and the fusible links on the front end of the engine space Electrical/relay box. Search the subject.Good luck with it.
