Mk6 Jetta: Hard Start / No Start - Intercooler icing discussion in here!
If you have experienced intercooler icing, select from the following options...
  • Total voters
    145
6speed13jedi
Maryland
2013 Jetta TDI
Issues starting, Intercooler ?
Hi everyone, I'm pretty new here I have a 13' Jetta 6speed and I have about 6000 miles on it and I drove it to school the other morning and it was about 20 degrees when I left and then when I got in the car to go home it was about 40-45 degrees and I turned the key and she tried to crank and nothing and I tried again and it cranked once and nothing, I tried two more times and those times it ran rough and shut off. On the last try it sputtered and sputtered and I bliped the throttle and it started to idle normally. Was this the intercooler icing issue ? I don't know much about the intercooler icing problem but its been sub ten degrees all week and its ran like a champ. What should I look for or avoid ?
RDC98tdi
Louisville KY
'13 Jetta 6MT Prem / (RIP) '98 Jetta 5MT [280k+mi]
Sure sounds like it. I am so mad at VW for continuing to sell a car with the issue happening SO DAMN MUCH. Even if only the people who posted on this site were the only ones who had the issue, that would be a large percentage of Jetta TDI owners.
VW needs to have a look at their QC and design process.
But yes, OP that's exactly what it sounds like.
The icing is caused by large temperature inversions that cause condensation to get into the intercooler, freeze, thaw etc. The ice or condensation then either creates a sludge and plugs up sensors, or the engine sucks it up and can wreak havoc on cylinders and valves. Next time this happens, call the dealer immediately and try to get a tow so they can see evidence. (Hopefully it does not happen again)
6speed13jedi
Maryland
2013 Jetta TDI
Thanks for the info I was pretty sure that what happened, This is just my first TDI and I want to get it sorted out ASAP because its also my first brand new car
ShawnShady
Idk
2013 Jetta TDi 3 Pedals
Does the egr valve have anything to do with the icing or gunk build-up?
Jettagain
New England
2012 Jetta (Prem/Nav/DSG)
Happened again this morning....This time no start...so i left it in my garage. The dealer asked me if i had any lights or codes, told them no lights or codes...They said it would be hard for them to prove anything (They believe). I guess i'll see if it starts in the morning. I like the car but in the end, if it wont run, it wont run. It just hit 60K and has been flawless up to this point...All service performed timely and is as clean as it was on day one...
JSWTDI09
Las Vegas, Nevada
While it is still under warranty get VW to install the intercooler fix TSB. It will be costly if you wait until the warranty is over.
Have Fun!
Don
Brewmaster
Nova Scotia
2016 GolF R : Oryx White
I'd call the dealership and have it towed in, as you said, it won't run. Tell 'em you have all symptoms of intercooler issue and ask they check there first. If they play dumb give them the TSB number.
MAXecutive
New York
Jetta VI
UPDATE:
The dealer's diagnosed the car and determined that it was a frozen intercooler. They removed the IC hoses and found sludge inside. VWoA reviewed the case and decided to pay 100% parts and labor for the Cold Weather IC Retrofit. The dealer cleaned out the hoses and gave the car back to me until they get the parts in.
I noticed that the car still has a sluggish feeling to it. When driving in 6th gear at 60mph, it feels like I'm lugging the motor and trying to do 50mph in 6th. The 65-70mph 6th gear pull requires a noticeable amount of more pedal effort. Could this be issues with the MAP sensor or more ice forming causing restricted air flow? The weather has been up and down near freezing last week and now below freezing all this week. Today I noticed some slight loss of power after rolling in traffic around 45mph in 4th gear. After doing 60mph afterwards, it felt a little better. The weather was 16 degrees and the car sat for 2 days.
I had concerns of potential compressor surge due to my highway stall incident. I was forcing a lot of boost into clogged pipping. I called the dealer to mention this and they told me the diverted valve would take care if that extra pressure. I'm not sure how that system works on this car. My assumption is that it would be closed under load and only open up when I let off the gas pedal. Or does that depend on the placement of the MAP sensor, before or after IC?
bhtooefr
Newark, OH
None
Diverter valve? On a stock TDI? Nope.
Anyway, given that you suffered an engine power reduction that resulted in a failure to maintain speed, be sure to report the incident to the NHTSA.
MAXecutive
New York
Jetta VI
I definitely will. Jumping 5 lanes of thruway traffic accelerating after a toll plaza isn't fun !!!
ChiTownPilot
Valparaiso, IN
2013 Jetta TDI + Premium
Just got off the phone with the dealer. They are going to put the kit on. Dont know if that will help but at least its a step.
Asked for compression numbers again we will see if I get those.
C4markee: Out of curiosity are they doing it free of charge (looks like you are out of warranty)? I only ask because this happened to me the other day and even though I had it towed to the dealership they were insistant that it couldn't have been IC Icing because "they've never seen it before" and actually tried to teach me how to start my car (they assumed user error). Anyway my worry is that I may be out of warranty (I put a decent amount of miles on it) before it happens again and I was curious if they will take care of it still. Like you I had the no start documented so I hope that helps if this is the scenario for me.
Engineers<3Diesel
North Carolina
2012 VW Jetta TDI
ChiTownPilot - I had mine done outside of warrenty. Car was completely locked up and had to have it towed in. As I live in NC it was the first the dealer had ever seen of the issue. VW covered everything and I was outside of my 36k mile warranty. It did say "good faith" on my invoice so not sure if they are covering 100% of them, but be polite and talk directly to VWOA if needed.
mac5155
PA
2011 Jetta
This car should come with Prozac (re: intercooler icing)
2011 Jetta w/ 70k miles. No IC icing since I've owned it (34k miles and 1 year) but it has been below freezing for 2 weeks straight now. I monitor everything closely. When I start it up, it starts normally. A bit of a shudder the first few seconds, wait 20-30 seconds, and go. The shudder has me worried. Going to pull the IC hose this weekend and see if anything's in there. No movement in the RPMs when shudder occurs and it's barely noticeable. Someone, please calm my fears :confused:
La Conner, WA
Attention Mk6 Jetta owners!
Due to the high volume of intercooler icing threads popping up with the cold weather, I'm creating a STICKY thread in this forum to contain all intercooler icing related discussions. This will make it easier to find information in the future, rather than have a dozen threads about similar issues.
Bear with me as I combine old threads in the Mk6 Jetta forum into this sticky thread. Some posts may seem out of sequence, but that's because multiple threads are being combined into one.
If you're looking for more information on intercooler icing and cold weather no-start related issues, please see (and contribute to) the following thread...
Main TDIClub intercooler icing thread: http://forums.tdiclub.com/showthread.php?t=302863
ORIGINAL THREAD/PROBLEM SUMMARY:
UPDATE 12/21/13
New TSB issued that includes all VWs with CBEA and CJAA engines (Audi A3 is unknown), including Beetle and Beetle Convertible. See attached PDF for complete TSB.
Intercooler kit changeover valve revised from 0C to 10C.
Current TSB in PDF format
-VeeDubTDI
UPDATE 01/18/12
GraniteRooster's Frozen Charge Air Cooler (Intercooler) FAQ / Problem Summary
In an attempt to provide to most relevant details to the forum in summary format, I have compiled the following brief of the issues. This is multifaceted problem whose unresolved issues and discussion runs much deeper than this summary - I'd encourage folks to read the thread in detail for best understanding. At 1900+ posts and counting, you'll need a cup of coffee/tea and comfy chair ;)
Problem
When driving in winter conditions (below ~20-25°F), external airflow over the air-air intercooler (IC) is cold enough to cause internal ice buildup in the IC and outlet charge hose assembly. Ice buildup may lead to a variety of operational difficulties including restricted intake, reduced power, LIMP mode, engine stumbling, melt water or ice ingestion, and catastrophic engine damage.
Affected Engines
All 2.0L CR TDI engines (CJAA/CBEA) installed in all 2009-2012 model year Jetta TDI, Jetta Sportwagen TDI, and Golf TDI vehicles. Vehicles in both US and Canada are affected.
Occurrence
Ice buildup occurs while driving in cold winter conditions, typically below ~20-25°F. Melt water and ice ingestion may be experienced on subsequent engine start if the car is allowed to thaw while parked (such as in a warm garage, or warm parking lot above freezing temperatures).
Causes
This is a thermodynamic phenomenon caused by condensation and subsequent freezing or direct vapor deposition of water vapor as the turbo-compressed charge air is cooled through the IC and outlet charge hose assembly. Two main aspects of engine design contribute to the problem:
  1. Low-pressure EGR is used to control NOx formation for emissions compliance, however, this recirculates water vapor rich exhaust back to the turbo and IC.
  2. The IC design on these vehicles is very efficient, providing good heat transfer and economy (and good ice formation under proper conditions)
Symptoms
Ice
  • Restricted Intake & Reduced Power
  • LIMP Mode (flashing MIL’s, “Service Now” message)
  • Engine will not turn over (complete ice obstruction of intake)
  • Catastrophic engine damage (ice chip ingestion)
Water
  • Engine will not turn over, "dead battery" starter action (due to hydraulic resistance in cylinder)
  • Starter/electrical fires (due to starter overheating during attempts to start locked engine)
  • Engine will turn over slow / not start (drowning)
  • Engine will misfire, stumble, and run roughly upon starting (water ingestion)
  • Engine will misfire, stumble and run roughly upon acceleration (water ingestion)
  • Catastrophic engine damage (water ingestion – hydrolock)
Solutions
VW has issued Technical Service Bulletin (TSB) TSB # 21 11 06 / 2025464 Frozen Charge Air Cooler. The kit may be installed by dealers on documented vehicles under original 36k warranty. Customers outside 36k warranty have often been denied installation under 60k powertrain warranty.
A (basically ineffective placebo) temporary solution implemented by VW involves removal of the forward facing cold air intake "snorkle" so that the airbox draws air from the engine bay, which allegedly may be warmer. In practice, TDIClub member testing has shown this modification to make insignificant changes to intake air temperatures, and is therefore ineffective.
What to Do - Frozen IC happened to me! :eek: :( :mad:
If the car won't start after one attempt, or stumbles and dies after an initial attempt, ***STOP!*** You have some decision making to do...
Further attempts to start the engine may (or may not) cause damage from minor to catastrophic. Depending on the amount of water in the intake and engine, damage may occur to pistons, connecting rods, glow plugs, injectors, head gaskets, etc. due to hydraulic lock. There is also risk of starter and electrical system damage from repeated start attempts against a locked engine. You will need to choose:
  • Service the car (preferred) , or
  • Attempt to start the engine and get where you are going (risky)
The best solution is to clear the intake and engine of water and ice before starting. However, it seems the engines are often able to pass melt water with undetectable or no damage. The preferred actions are:
  • Option 1: If under 36k warranty period, have the car towed to a VW dealer by VWoA to have the water and ice drained out and problem documented for installation of Technical Service Bulletin (TSB) TSB # 21 11 06 / 2025464 Frozen Charge Air Cooler. Dealers typically will require this hands-on service and documentation to gain required approval from VWoA for installation of the IC TSB under warranty.
  • Option 2: Elevate the front of the car on jackstands, remove belly pan and lower IC outlet charge hose, remove water and ice from assembly. Reassemble and drive. This option will not be convenient for a typical owner in most typical situations, given need for jacks, stands, tools, light, etc. plus safe environment and time to complete the repair.
  • Option 3: Have vehicle towed to appropriate repair facility for removal of water and ice from the IC assembly
Owners should report problems to their VW dealer and VWoA (1-800-822-8987) (or VWoC, etc.) as they occur. VWoA has the ultimate say in warranty installation of IC Kits; they rely on dealers to be gatekeepers on diagnosis, therefore dissatisfied owners having difficulty with installation approval should increase negotiations directly with both dealer and VWoA. Owners with safety concerns due to this issue should contact NHTSA and report their concerns.
UPDATE 01/17/12
Click hyperlink for .PDF copy of TSB # 21 11 06 / 2025464
(Credit 740GLE Post #1352)
UPDATE 09/14/11
TSB # 21 11 01 / 2025464 dated May 24, 2011 has been super-ceded by TSB # 21 11 02 / 2025464 dated June 14, 2011 and most recently, TSB # 21 11 06 / 2025464 dated September 6, 2011. The latest TSB referenced updates to warranty table and labor information. It may be helpful to reference the latest TSB when requesting warranty work.
(Credit Aerox Post #1003)
UPDATE 6/2011
There is now a TSB with a fix for this issue. TSB # 21 11 01 / 2025464 dated May 24, 2011, titled "Frozen Charge Air Cooler – Engine Will Not Start". It calls for installing a 1K0-198-803-B Cold Weather Intercooler Kit.
The kit includes:
  • New Intercooler (IC) with internal vacuum-actuated flap valve
  • Vacuum Sensor
  • Intake Elbow with Temperature Probe & Vacuum Actuator
  • required plumbing
Installation requires 3-4 hours labor and corresponding ECU software update. This kit was installed on my car by VW on 07/06/2011. Here are pictures of the kit installed on my '10 JSW, as seen from the front of the engine compartment. The post-IC intake charge temperature/vacuum actuator are circled in red. The rest of the kit is not easily viewed without removing the engine belly pan, etc.
EDIT 03/07/2012: Member UberVW_TDI posted nice pictures of the components of the kit in Post 792.
Integrated Temperature Sensor and Vacuum Switch / Blending Valve mounted on Elbow
Intercooler with vacuum actuated diverter valve
03G-906-051-K (VACUUM SENSOR)
EDIT 03/07/2012: Member PAJettaTDI posted good photos of his installation in his photo thread.
ORIGINAL POST 12-17-2010
**I posted this at the end of the "Cold Start/Scare" thread in the MK5 forum - but thought I would post here in Mk6 JSW as well for the benefit of MK6 owners who do not frequent the MK5 forum... I hope that is OK.**
After a longtime lurking I have something to say and its not good - my car has been having significant icing problems as well.
I commute 100 miles each way from Northern NH to Southern NH 4 times a week. I leave at 5am and return at 5pm. Obviously NH is subject to freeze thaw cycles and we have been having some very rainy, humid conditions this November/Early December.
I have had rough starts with symptoms of water being drawn through the engine 4-5 times in the last 3 weeks. I have had the engine not turn over once.... paused 5-10 sec, checked myself, tried again, and cranked but caught rough and stumbled for 45-60sec...., and then again once pulling out of parking lot, engine RPM's (and airflow) rising, more stumble.
Then, Tuesday Dec 14th driving home, left South NH in 27 F degrees, rain, snow mix and temperature falling rapidly. 25 minutes into the drive, precip has transitioned to mostly snow, and temperature now 14 F degrees and still falling. 72mph in left lane, power cuts, Service NOW message, Glow Plug lights flashing. Finished 70 mile drive home with engine in LIMP mode and 10 degree external temperatures, wondering if my HPFP was expired. I was low on fuel, so left engine idling in LIMP and filled up with my favorite B5 before continuing home and shut it off. Read most of this thread... holy cow this is not good.
Next morning, 8deg, car fires up, no CEL's, drive 100 miles to dealer and drop it off. They let it sit till lunch outside in freezing temps. Bring it into shop, they drained almost a cup of water and ice out of the intercooler lines.
This is major spooky as I have already had one start that was "hydro-locked", but I didn;t know what was going on at this time so I forced it and it started horrible. I am real concerned about major long term engine damage from regular ingestion of big slugs of water caused by this icing/melt problem. This car is 10 months old with 33,000 miles, driven very regular route, broken in well and driven accordingly, 2 out of 3 fillups with B5 and the rest straight ULSD always from the same two stations, so the average bio-concentration in the tank is is usually B2-B4..... I intended to keep this car a long time, but having it ice up a couple times a week for several months of the year is just not going to work.
Dealer considers car fixed until it throws another code... and it doesn't throw a code when it hydrolocks or or rough starts. I question how many more times this can happen before I have bent or broken rods and worse.
Thanks to all for very cool and informative forum here - I have learned a lot and enjoyed my TDI very much until now. Thought I would let you all know of another iced up intercooler.
I am also starting a case with VWoA - the more the merrier.
mac5155
PA
2011 Jetta
heh. I certainly hope my thread wasn't the straw that broke the camel's back. I'll x-post it here. Apologies:
La Conner, WA
No problem at all, mac... just trying to keep all of the pertinent information in one easy-to-find locations. :)
Engineers<3Diesel
North Carolina
2012 VW Jetta TDI
Agreed with the above. Mine wouldn't crank and had it towed immediately (I was outside of warranty). Called the dealer first thing in the morning, told them it was hydro locked and provided them with the TSB. As I live in NC they had never seen it before but confirmed it quickly and got me the new IC and kit. They covered everything and I've had no issues even with the recent cold snap where it has been well below freezing in the morning but above freezing in the afternoon.
Dozenspeed
I'm in my third winter, original IC. I wouldn't fear what you've experienced thus far, but expect it from a diesel in the cold. It may need a few seconds to sort out and is unlikely to be perfect from rpm 1.
But you should be concerned. Only once or twice has mine acted unhappy, and that was winter 1. I run the car 1 minute and allow Torque to connect. I spike the throttle to about 1600 rpm to ensure clarity, and gently drive off, slowly increasing rpm range as the car warms up. She runs an average of 180+ miles a day, everyday, so full proper heat cycles are the norm. (It takes at least 30 minutes of driving in my opinion to fully heat the car when below freezing.) When appropriate, I regularly "WOT" to ~4000 rpm (6MT) to keep her warm and exercised. I feel this is the key. More air = drier intercooler. :confused:
I now have the IC pipe opened and drained at every oil change. Even though something in there is normal, I like to remove whatever I can like a maintenance so that "capacity" can be retained.
Hope that helps! :)
mac5155
PA
2011 Jetta
Calms me a bit, yes. I have a 150 mile round trip commute of which all but 15 miles is highway. Run 70-80 mph and almost always above 2k RPMs. Due for the 70k oil change this week. When my shop can get me in I'm going to introduce them to the frozen IC issue (they don't see many MK VIs) and have them pull my lines and clean it out.
La Conner, WA
Pull the passenger's side boost pipe and see if there is an accumulation of liquid in there.
Jayg
Anchorage, AK
'12 Jetta 6MT-VW bought back as a lemon
Got an email from VW stating they were replacing my DPF. Either they are completely retarded or my particulate filter broke at the same time as the IC freezing issue. It's been in the shop for a week now and will be for maybe another week. Almost 40 days total since Oct 2012.
Either way, Lemon Law time. All paperwork was submitted to VWOA and the Governor's office of Consumer affairs. I can't have every ****ing thing replaced on this car all the time. Meticulously maintained and cared for and this is what happens.2 trips to the dealer on a flatbed, IC freezing, DPF replacement, trunk leaks, electrical short under the dash....this is the definition of a lemon at 21k miles and 15 months old.
I see people ***** and moan on here and other people tell them to stop worrying about it. I sit on the sidelines and decide I'll make my own conclusions. Well, after all this I have to say I have had a terrible VW owner experience. I'm not bashing the brand or calling anybody dumb for owning these cars (I made the same purchase). I'm not looking for sympathy or fanbois to call me names or that I shouldn't have taken it to a dealer or that I should just go get a Honda. I am simply sharing my story so others can get some insight and maybe it will help somebody.
La Conner, WA
Sounds like a real nightmare. I'm curious what your code was for the rough regens after the IC "fix."
Jayg
Anchorage, AK
It was essentially a boost leak code from when I asked last week. It had something to do with the chargecooler so I assumed it was a missing gasket as some have reported on here.
So you can imagine to my surpise with I get "The DPF is getting replaced." Even when I brought it in the day before for running rough, no check engine lights, no codes, and the ash level was perfect.
The techs are clueless but one thing for sure is that this car would cost me thousands out of warranty.
La Conner, WA
Your compression looks good - within spec without much variance.
6DOF
Senatobia, MS
2011 TDI Jetta 6MT Premium, 2012 TDI Jetta DSG Premium
Since it is too cold to do anything outside today, I took my intercooler apart and found some sludge on the outlet (passenger) side and normal slight oil residue on the inlet (driver) side. No water to speak of but an 8-10mm thick deposit stream of the sludge from the intercooler halfway up the intake cavity. I removed and thoroughly cleaned it all up. This took a lot of rags. Finally got to use my new boroscope to verify all the sludge was removed.
The inlet is on the left and outlet on the right in the picture.
url=http://pics.tdiclub.com/showphoto.php?photo=102087&title=intercooler&cat=500]
[/url]
javascript:;
http://pics.tdiclub.com/showfull.php?photo=102087
http://www.ebay.com/itm/7mm-Inspect...879?pt=LH_DefaultDomain_0&hash=item3cdb654127
tkbalt
Indianapolis
2011 Golf (DSG) and 2013 Passat SEL (DSG) TDI's
Intercooler issues
I have an 06 Jetta TDI with 92K and am looking at trading up to a newer vehicle. Have been thinking about a 13 or 14 Jetta TDI - but a little nervous about the inter-cooler issue that seems to be present on the 10+ models. Does the golf have the same issue (we have a 2011 Golf TDI). What about the Passat TDI?
May end up just sticking with our 06 Jetta and all of its quirks.
Softrockrenegade
Howellbama, NJ
None...2011 Golf DSG (replaced by VW W/) 2013 Passat SE 6M(bought back) Current 2017 sportwagen TSI 4Motion.
The passat has a air to water intercooler which solves the icing problem .
6DOF
Senatobia, MS
http://www.ebay.com/itm/7mm-Inspect...364?pt=LH_DefaultDomain_0&hash=item5d3efe37dc
