Moses Buckwalter
Hello! I have purchased a 6 Speed transmission from Europe and I'm looking to do a swap on my 02 ALH TDI Golf. I've done a lot of scouring the internet, and the guides all seem to be a bit inconsistent and inconclusive so I'm hoping to get some responses from people who have done this swap. My current parts list is as follows
6 speed O2M EFF
6 Speed Starter
6 Speed Shifter Bracket and Transmission Bracket
6 Speed Engine Mount
6 Speed O2M Sachs DMF and Clutch Kit
Clutch Line - heard the 5 speed one could be bent, but I'm going to just purchase a new one
T Bleeder
Shifter ends x 2 - this is what I'm confused about, I was told the linkage is fine to use from the 5 to 6 speed, but not the ends, however all the parts websites show the ends as compatible between all MK4 models.
Full Bolt Kit
Dust Tin - Multiple people have said this is different, but the guy I purchased the transmission from assured me it's the same between the O2J and the O2M
Axles - Will be purchasing a used set, although I hear that only the driver's side one is different between the 2.
I've also heard that some of the hubs are different for different axles, but it seems that the only axles that wouldn't work are R32/AWD TT ones?
I've also heard that the power steering line need's some bending to work, but that it can work. Does anyone have a link for the correct one, should I want to do that, or have any insight on if doing that is worth it?
Is there anything I'm missing here? Hoping to have everything ordered so I don't run into any snags along the way! Thanks!
6 speed O2M EFF
6 Speed Starter
T Bleeder
Full Bolt Kit
