I am also about to do the same. I think I am going to go with the quiet smf as well. I think I am going to try the idparts branded clutch. Peter said it holds good on his alh golf with RC3. http://www.idparts.com/complete-clutch-conversion-kit-a4-p-3860.html
If more people have feed back that would be awesome especially if they can compare to other clutches.
What is the difficulty of installing a clutch? I have looked up the process, but it seems easy and hard at the same time. My main concern is physically removing and putting back the transmission. I can have a two people help me, but I also won't have a lift.The SMF I installed was from IDParts ......... good price, fast shipping and no complaints from the lady or her husband and son!
Not too difficult, plus all modern cars are practically identical.What is the difficulty of installing a clutch? I have looked up the process, but it seems easy and hard at the same time. My main concern is physically removing and putting back the transmission. I can have a two people help me, but I also won't have a lift.
I am relatively handy, but very small. I have a torque wrench and lots of other standard tools/wrenches. If I get a strong friend and a creeper to help you think its doable in a garage with jack stands?Not too difficult, plus all modern cars are practically identical.
There are possible pitfalls, you remove several things and must get them back on correctly. All the parts are heavy and big, plus it's underneath. May need to get or fabricate special tool(s).
It requires some general car knowledge. You can find many utube videos to get a general idea. Then find a good tutorial guide, the Bentley is what many use.I am relatively handy, but very small. I have a torque wrench and lots of other standard tools/wrenches. If I get a strong friend and a creeper to help you think its doable in a garage with jack stands?
Loosen it while the wheel is on the ground, Breaker bar as needed and it will spin off like BUTTA. Not a terrible job, if you have someone to help you get it back into place it will make the job a ton easier.OK thank you guys so much for the info! I have the bently and I have done some wrenching so I think I am going to order a smf conversion. One question though with the drive shaft what are the chances of that coming off kind of easy? I know it is torqued on at like 200ftlb.
I had my 17 year old help start two of the bolts at the top of the bell housing. You can only hold the thing up there so long. Daughters are handy.. Had my 19 year old daughter help me since it was her car I was replacing the clutch on lol.
On the plus side my brakes have started singing today, bit like being at the opera
Yup, she is rather proud of herself for having helped fix her car.I had my 17 year old help start two of the bolts at the top of the bell housing. You can only hold the thing up there so long. Daughters are handy.
Who would've thought?
These cars are just so much fun! No really?
You may need to source it elsewhere. Possibly they don't sell that kit where you are. They might sell it under a different name or even no. Researching parts is getting harder than it used to be...................Anyway I'm having trouble with my friends shop, the supplier insists on sachs kit 3000 384 001 but that's the VR6 kit.
I'm trying to get 3000 332 001 as per idparts part number for the silent kit. I had the VR6 one last time but it rattled a fair bit at idle. ..................
I've done two with the car on jack stands. The gearbox itself weighs about eighty pounds or so. I held that side of the engine up w/ a hoist from one of the floor joists from the overhead in my shop.I am relatively handy, but very small. I have a torque wrench and lots of other standard tools/wrenches. If I get a strong friend and a creeper to help you think its doable in a garage with jack stands?
