aztecducky
Feel free to post your own brake upgrades here!
Here's my 03 Jetta TDI. I used 986 generation non-S Porsche Boxster Brembo 4 pot calipers front and rear with OEM Brembo pads and hardware. I went with these over the 17Z/18Z big 6 pots so I wouldn't have to install a different master cylinder as the factory one doesn't move enough fluid to actuate those big brakes effectively.
Front adapters are Creations Motorsport BR0023 with their BL01 *front* stainless brake lines.
Rear adapters are Creations Motorsport BR0035 with their BL01 *rear* stainless brake lines.
Rear parking brake calipers are mk4 R32 calipers.
Front rotors are 312x25mm from the mk4 Anniversary GTIs and some first gen TTs
Rear rotors are 280x22mm which are factory size mk4 2.0/TDI *front* rotors
In order for the fronts to fit, I used Audi TT front knuckles, ball joints, and control arms. You can also use R32 parts, and probably 1.8T/VR6 parts. Car is on Airlift Performance bags and I'm running custom made 18x8.5 et30 wheels.
Front caliper fitment was very tight, rear fitment required grinding about 0.5mm of metal from the inner corner of the Brembo calipers. Everything else bolted up as it should and fit perfectly. Here are some pics:
OEM front brakes vs the replacement parts:
Front brackets installed on TT knuckles:
Rear brakes installed:
Front brakes before:
Front brakes after:
Rear brakes before:
Rear brakes after, you can see where I had to clearance the calipers slightly:
Everything installed:
Front brakes are a very tight fit but don't rub:
Front brakes after:
Rear brakes before:
