Mk4 ,AGR AHL engine sounding damn loud ticking sound
Stano
Zimbabwe
Hi guys.
I have 1999 Golf mk4 1.9tdi AGR/AHL engine the other day i hit some pretty rough corrogated dirt road ,and begun sounding rough and loud more of a ticking sound like the engine gonna Crack, engine got not much or abnormal vibrations. The noise is heard and louder apon acceleration, not heard while idling. Pls Help!
BobnOH
not-a-mechanic
central Ohio
New Beetle 2003 manual
If you can't find anything up top, remove the lower engine cover and check for any loose piping.
Stano
Zimbabwe
I wonder if you've had an injector come loose? Something surely has. Be very cautious when inspecting them while the engine is running.
Maybe inspect them and their hold-downs while it's not running first.
I will have open up and have a good look at what's happening inside there with the injectors. Many thanks for the advice. Will update when done
Seatman
Scotland
2014 Skoda rapid elegance 1.6 cr tdi
Hi guys.
Check the exhaust, might have broken the downpipe. The flexi can often crack.
PS What horsepower is your golf? Might be the AHF engine which is the 110 hp
ALH is 90 hp with vnt type turbo and AGR is like the ALH but with a wastegate type turbo.
Stano
Zimbabwe
My bad typing error on earlier post ...it's a 90Hp AGR engine -Yes its a Westgate type turbo. I will take a good look at the you have highlighted . Thanks
