Zacque
Hey there, I have a BEW TDI with just over 215,000 miles on it. I've owned it for a little over 6 years. I replaced the alternator about 6 months ago, and the battery last month. Despite this, when I start the vehicle now it pops the Battery, Brake, ABS, and Air Bag lights, but they are confusing. Sometimes they flicker as I start or drive, and sometimes they stay until I put the car in drive and hit the gas.
Also, the EGR was ripped out the end of 2019.
I ran VCDS on it and it came up with these codes:
Engine:
P0407 EGR Sensor 2 (not sure how to clear it)
P3007 Camshaft Position Sensor G40
P0118 Engine Coolant Temp Sensor G62
P0101 Mass Air Flow Sensor G70
Trans:
Transmission Fluid Temp Sensor G93
Brake Light Switch F
Airbags:
Supply Voltage B+
Central:
Window Regulator Switch E40 Front Left (this has gone out before, the new one in the driver door is no more than 2 years old. I replaced the switch and the locking solenoid.)
Thank you so much, the posts and comments from this site have helped me fix my car numerous times over the years. Any insight or advice or pointers would be a huge help !
My concern with all of this is that there is a larger electrical issue in the car. I wonder if it could be the Engine Control Module or the wiring harness that runs from the ECM to all these sensors. Have anyone seen this before in an ECM failure? Or do you have a hunch of what the true problem could be?
Engine:
Trans:
Airbags:
Supply Voltage B+
Central:
