84Gliracer
Does anyone else make a custom bracket besides Darkside for VNT setup on MK2 /3 , looking for New or use if you have one
????? thisI used a 2005 Passat manifold with a GTB1756VK. No modification to the engine mount required.
BHW exhaust manifold. Yep. An AFN will work too.????? this
This is an old post but is this pdf still available? ThanksIf you have fabrication abilities or know someone who does I offer a .pdf of my engine mount bracket that can be used as a template to cut the pieces needed to make one out of steel. I will be offering finished mounts at some point later. PM me for details.
I'd like it too, if it's availableThis is an old post but is this pdf still available? Thanks
